Hey all,
Trying to install a set of QFM pads I bought from a guy here. The back ones were easy. Removed the old, grabbed the old brake pad in the caliper to compress the piston. Slide out and insert new one.
The front is being a bitch. I can't compress it. No matter how hard I squeeze it(using those adjustable plier things). When the pads are in and on the car and someone presses the brake, I can feel them moving, I just cant push them back. Does anyone have any advice? Do these need to be turned or forced?
R33 GTST Series 2.
https://www.sau.com.au/forums/topic/354699-changing-brake-pads-help/
firstly, be careful!
the piston needs to slide back straight into the caliper. if you try and force it at an angle it might seize. and if you push even harder you might manage to score the bore and damage it permanently.
firstly....clean everything really well with brake cleaner. this will remove as much old brake dust as possible. even scrub lightly around the piston with a nylon brush.
then - before pushing it back, make sure your master cylinder is almost empty. If it is not it will overflow when you push the pistons back.
then, you need to push them back as straight as possible. use something long and wide to lever them downwards like a large spanner or thin hammer. take it slowly and change from side to side to make sure they go evenly. a g clamp is even better it will push them back straight.
I will buy some brake cleaner tomorrow. I don't want to interfere with the hydraulic system as I just recently had my fluid topped and bleed properly.
Can I do one piston at a time or should I do both at once? One at a time I can use a clamp to squeeze each one in. I can squeeze the 2nd brake pad in its just the one that sits on the outer side I cant push in.
they should all retract exactly the same way. if one is much tighter it is probably not straight or already seized.
as you push one piston in all the others will want to move out. you have to push them all together, or hold 3 while you push the other one
I normall leave a brake pad in against the pistons u are pushing on. This helps move them together and keep them square.
Use the adjustable multi grip pliers and squeeze.
If ur brake fluid has recently been topped up then once u push the pistons into the caliper there will be brake fluid all over the firewall. When this happens wash it down immediately with water
f**k finally done with just slightly overflowing the fluid bottle. I used a multi grip, the one with the screw end to adjust bite, and a piece of cardboard wedged between the pad and the rotor to ensure it sits flat as possible and slowly squeeze then adjust the tool to be tighter then squeeze until I fit the other one in.
I cleaned off as much of the gunk as I could and I think that helped.
Cheers guys, now I just need to find the damn retaining clip for the push pins.
Its not the wire part bro its the metal thing which puts tension on the two pins, the flappy piece of metal. I went to a skyline wrecker and he wont sell it to me because he reckons he wont be able to sell the caliper without it lol.
%21B6d%21lowEWk%7E$%28KGrHqF,%21g8EyrpG2ZJEBM%29YR-JeM%21%7E%7E_1.JPG?set_id=8800005007
Its the n parts you can see above NIssan. Where can I get them? Are they essential to have? Would Nissan have them? Ive been driving my car since I bought it, without it lol.
umm that is not ideal, the spring clips hold the pad in the caliper.
I have used r pins for years instead of the wire to hold the pins in, but I've never tried it without the spring clips
well the pins should keep the pads in the caliper ok, but from memory the spring clip works to keep the pads up against the pistons. without them the pads 'might' rattle around a bit on the pins but most likely they'll be ok. personally though I would just call up nissan and buy a pair and stick them in. they are not expensive (maybe $20 for a pair) and easy to put in.
BTW when you were first trying to push the pistons in did you have the cap off the master cylinder? seen plenty of people trying to push pistons in with the cap still on which makes things pretty hard as the system is sealed so there's no room for that pressure to go. eventually the pressure will escape somewhere (usually through the cap) but sometimes it pops post the master cylinder seal etc which is not good.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
