I have had a client pull out with their RB26 build and left me with a lot of parts around the shop that I would liked moved on
- Eagle 1500hp Rods
- Wiseco 86.5mm Pistons & Rings
- Cometic Gasket kit lower and upper plus 1.3mm head gasket
- ARP Studs Head and Mains
- ACL Race Bearings +0.25mm Size mains + +0.25mm size big ends STD is available
- Valve guides supertech
- Spring retainers titanium supertech
- Double Valve Springs Supertech
- ATI 600-1000hp street balancer part #917752
- Nismo engine & tranny mounts R32 GTR/GTS4
- Brain Crower Valves standard size inlet
- Supertech valves 1mm oversize exhaust
- Welsh Pull kit head and block
- Nismo FPR
- ZEX Nitrous WET kit with every jet up to 170hp shot
- Cosworth Air Filter for factory airbox part #20002270
- RC 1200cc injectors
Engine heater and radiator hose kit silicon
- Tomei Lifters
- Kelford RB26 R32/33 GTR Cams 272 Duration 10mm lift both cams
- HPI GTR DUMP Pipes
- Nitto RB Billet oil pump
As a complete kit the price is $12,500 if you would like some Garrett Turbo’s that will be on top.
We can also over a full engine build service if you require an engine built
Shipping is available Aus wide or international on top.
Contact Via PM or 0438804282 txt or ring please leave a voice message if I miss your call
Location is Sth east Melbourne
dmac: You are very familiar with the Trader rules on SAU.
Thread closed until such time as you become a registered SAU Trader and pay to advertise.
Admin
