Picture i took of my fiance today while we were out for lunch in freo.
All the rest of the photos i took are crap, too blurry :( Couldnt tell at the time.
PS Lepper, AMAZING photo!!!
Edited by Passive
  • Replies 182
Posted Images
got back from the clipsal 500 yesterday, I was working on one of the fujitsu cars basically around the clock so i didn't have a whole heap of time to snap happy, but i did manage to get a couple of really nice shots. I'll post up once i get a chance to check them on an actual screen.
Here's the only one I've got on a computer, and it's 100% straight from camera. No touchups or adjustments.
If you're bored, or half interested you can have a look at the team I was helping out here... Sieders Racing Team
My love for marine life became a reality 3 years ago when my neighbour help me to set up a nano tank with just live rocks and two fish. A year on and learning as much as possible I then upgraded to a huge 4ft tank with beautiful colourful corals and invertebrates. Coming from a such a small tank it was a huge step forward but well worth it. A lot of ups and downs on the way, but the tank is finally maturing successfully and is well established and stable.
Would like to thank my neighbour once again for helping me with this tank. Both of us spent over a week building the stand and doing all the plumbing work. Couldn't have done it without you mate!!!
The pictures below show the progress of the tank over the two years.
Week one:
Few months later:
A year later:
Currently how it looks.. tho the pic was taken end of last year so a few minor changes:
Lots more pics here: http://sidd-rishi.com.au/blog/misc/my-marine-tank-turns-2/
Nice shot there matt. My only cc is the crop of that image. If only i could see a bit more of the background. Seems like such a tight crop of the car. But then again thats just my personal taste.
Ryhs - Cheers mate :)
cheers sidd.
i think the light looks funny because it's bending around the front bar. that shot's legit, and the lighting is directly from the actually lights on the car. that's the only thing i can think of. there's no gay photoshop flares here baby! :P
Nice pic passive. A Little bit more light would be nice though but i guess it wasn't available? :)
Duncans GTR Peeking out at NSW State champs today (yesterday).
Yeah not really much light where we were sitting :(
I turned the ISO down on my camera too to try and make it less grainy but i dont have the stability to hold the camera for longish shots :P
Lots more pics here: http://sidd-rishi.co...e-tank-turns-2/
Wow really amazing tank!
My uncle has a huge tank at his place, heaps of fish but theyre super aggressive so he has to be careful which ones he buys because theyll get eaten...
Eric - thanks mate.
Andy - how'd you take no.1? Waterproof cam or tele from the shore...?
waterproof cover for canon...was actually quite close to the subject...risky shot as we were in very shallow reef, was a lot harder to shoot than it looks!
i actually like the lighting in that shot of the duncmobile. it helps the car stand out and looks mean. If you don't like dark car shots you probably won't like this one then :P
P.s. nice work sidd. capturing those eyes!
Was it raining when you took that shot matt? Can see heaps of spots over the image. Im guessing rain on the lens? Otherwise nice shot :)
Cheers dude.. love capturing beautiful big bold eyes!!!
passive - cheers mate :) yea you gotta research before you put stuff into your tank.
Edited by siddr20
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
