Hey gangstas
Looking to replace the shocks in my s2 R33 gtst, tossing up between Tein super streets and KYB Excel-G struts. Have super streets in my ST185 GT4 and found them an awesome unit for the price. Can get a set from perfectrun.com for $1700-ish delivered - the best price I have found for a set of the KYB's is around $1000, plus the cost of new bump stops, boots, set of spring compressors, so prob about $1100 all up. Not looking to do anything amazing with the car, just a nice streetable ride, so I'm thinking I would just be paying more for the Teins to get the adjustability of the height/damper settings, which I don't really need. The car is stock so far apart from 17x8 drifteks, front strut brace and factory rear strut brace, 20mm whiteline fixed swaybar on the rear, and 24mm whiteline adjustable swaybar on the front.
So my questions
- is around $1000 for a set of the KYB's a fair price, or can they be found cheaper? (have got similar prices from 2 places so far) and if so, who to call?
- is the quality of the shocks comparable between the KYB's and the Tein super streets?
- is it worthwhile fitting a subframe lock kit (pineapples), and castor rod bushes? Worthwhile meaning, is it something you would fit and go, goddamn, glad I spent the money and did that, or more like, hmmmmm, little bit better but not heaps. The superpro subframe kit looks to be much better value with 8 bushes for $80-ish as opposed to 6 in the whiteline kit for $100-plus, any real other difference between the 2 in terms of quality and performance?
Any thoughts and opinions on the above would be appreciated :)
https://www.sau.com.au/forums/topic/355728-tein-ss-vs-kyb-excel-g/
ok well I'll answer my own questions lol
- best price I found for a set of the KYB's was $800, from GSA Wholesale in Brissy. Would mean paying the freight cost thought, but would still be about $100 cheaper. Guy there was very helpful too
- the quality between the 2 is comparable, with KYB probably being higher/longer lasting ( this from talking to bloke at suspension place)
- no idea as yet. Opinions on the board here seem to range from awesome to not a great deal of difference noted. Since it would be around the 200 mark to buy both kits, I might leave it and put the funds into the struts at this stage..
bullshit KYBs are equivalent, tein SS get a great rap on every forum read, KYB are standard issue on alot of new cars..So they are not really any better than standard shocks...In fact they are just standard shocks
Teins all the way mate if you can afford it..or if you dont need adjustment just get some koni or bilsteins shocks which will handle better then the teins anyway
koni's are shit, yellows at least, that I have tried. I don't rate them at all. Bilsteins I have read are the bizz, but if I'm going to spend any more I would just get a set of Tein coilovers.
Tein ss get a great rap for the performance edge...which i feel they deserve. However, my original post refers to the *quality* of the shocks, not the performance. I'm not confused about which one will give me better performance, for I know it be true that Teins will have the sportier edge. My r33 still has the original shocks after 103,000k's, no leaks, no knocks, which I am pretty sure are KYB's. That says a pretty solid build quality to me. As much as I like Teins, I have my doubts they will last that long..
do you want tein adjustables cos you think you will change the height frequently or because you want to use the different adjustments for performance gains for use on the track?
bilsteins and springs and swaybars will be sick for street..
actually, not really fussed about height adjustment, so i'm not shopping for springs. It's just that i have super streets in my other car, and like them, so would consider them for this car...wouldn't really be adjusting them at all after the initial fitting. Was trying to find a lower cost option though, like the kyb's. If i pay for bilsteins and springs, i might as well just buy a set of teins.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
