yes it does mate search for the installing diagram do not get it wrong or you can stuff ya engine up..
i've done some searches but cant seem to find anything saying or showing the was the lines should be. can you give me any links mate?
ok i'm stuck knowing where to put the braided lines from the sandwich plate on the block, you know how there are 2 fittings on it, one must be a return & the other bumps oil to the oil filter/relocater? then there are 2 fittings on the oil filter/relocater. 1 feeds oil from the sandwich plate & the other feeds oil to the oil cooler...
hope someone understands & can help cause i dont wanna get it wrong & f**k my engine due to lack of oil lol
cheers
ok here's a diagram i found where is says "spin on adapter is that the correct way the hoses have to go on the rb30?
or does the oil feed from the oil filter thread on the block?
Edited by HR31-PASSAGE
