Hey guys got my pride and joy up for sale,
Nissan Skyline R32 GTS-T Type-M
Year: 1992
Engine: RB20DET
Transmission: Manual
Kilometres: 193xxx genuine kilometres on the shell, 140xxx kilometres on the engine.
as the car currently sits it comes with the following mods:
- Complete GTR Front
- Rebuilt RB20 gearbox
- Exedy Heavy Duty Button Clutch
- R33 Control Arms
- R32 GTR/R33 GTS-T front brake upgrade with drilled rotors (standard
GTR)
- Bosch 040 Fuel Pump
- Respray by DT panels (well known and reputable panel shop here in
Melbourne)
- HKS 2530 turbo (most responsive turbo you can buy for RB20, was
rebuilt when i bought it)
- Trust Front Mount Intercooler
- Blitz Boost Gauge With Control Unit
- Cusco Rear Strut Brace
- Air Con Just Regassed
Serviced Regularly With All Synthetic Oils
It also comes with a current Victorian roadworthy certificate AND an
engineers certificate for the front mount and rear strut brace so it will
pass for rego in any state easily.
$11,500 can take off turbo and any other bolt on mods to make it cheaper.
Located Southeast Suburbs Melbourne, please PM any genuine enquiries low ballers ignored, dont like the price push the back button on your browser and keep your opinion to yourself
Cheers,
Kyle
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
