selling due to over it, dont drive it much anymore , more interested in my comfy dailylol
1993 series 2 r32
238 000 kms (still running strong , never broken down)
gun metal grey/black
44mm aluminium radiator
3" turbo back exhaust
exedy heavy duty clutch (installed less then 5000km ago
PWR big daddy bov
tien superstreet coilovers
turbosmart MBC set to 12psi
m-spec rear wing
rolled and flared guard's (fronts not complete due to the machine at my workshop couldnt clear the s2 front brakes)
GREDDY fmic w/ piping
autometer boost guage mounted in driver side air vent (circular vent on the right of the dash , needs new bulb)
cream interior minus driver seat , threw away due to wear and tear , and the shift boot looks like shit.
pioneer head unit and rear speakers , no front speakers.
k&n air filter
cut the coilpack cover so it doesnt trap the heat (will throw an uncut cover for no extra charge)
Regular servicing - every 5000km's ,
98 octane fuel always used
the body is pretty much in the condition that i got it, same with the interior, was going to turn it into project car after rego runs out but really dont want to spend the money
power steering pump is on its way out, i will supply one , (havent bothered to install)
the back half is black because i was bored and the paint was shit on the back, i had it all preped to get sprayed properly but couldnt afford it so though bugger it why not
it has a rear bar but isnt on the car, its still in primar , will install it again on the weekend or one day after work this week , the wing is still grey
missing the quarter window surround part on the driver side
rego until september 27 (NSW)
no accident history
no rust
runs great
Will throw in all spare parts i got laying around , including ps pump , timing cover , coil pack cover and what ever else i got.
i dont think there is much else to cover, ill update with more info if i can think of anything.
Chasing $6.5k ono , swaps for something of interest , just show me what you got
contact on 0431 121 625 or email me at [email protected]
sms preffered due to work (i work alot) , or if you call and i dont answer leave a message and ill call you back when i can
post-58990-0-04970300-1299060499_thumb.jpgpost-58990-0-28197600-1299060670_thumb.jpgpost-58990-0-33659700-1299060710_thumb.jpgpost-58990-0-47187200-1299060876_thumb.jpgpost-58990-0-15219200-1299061046_thumb.jpgpost-58990-0-84395100-1299061115_thumb.jpgpost-58990-0-85607200-1299061227_thumb.jpgpost-58990-0-29023800-1299061263_thumb.jpgpost-58990-0-46233500-1299061304_thumb.jpg
Edited by d_soljah
https://www.sau.com.au/forums/topic/355878-fs-1993-s2-r32-gtst/
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
