I'll be heading over for the V8's in a couple weeks from Sydney. Is there anything awesome I should try or visit while I'm there? I have absolutely 0% idea of what radelaide has to offer. I'm open to suggestions? Good bars, sight seeing, whatever.... suggest it!
thanks in advance!
https://www.sau.com.au/forums/topic/356372-radelaide/
I'll be flying over so twisties and drives are unlikely.
interested in beer
sight seeing, I'll be bring my camera along for some happy snaps
ummm... signature adelaide stuff that i can't find anywhere else, or stuff that you guys really love.
so general awesome stuff.
thanks for suggestions above. googling each of them now for more info :)
https://www.sau.com.au/forums/topic/356372-radelaide/#findComment-5702531
If you like Beer, try Belgian Beer Bar off Rundle Street.
Huge variety, liquid gold as they say.
^^^^ THIS, also the foods not too bad either.
If I go to town, I go there. f**k clubs and their horrid thing they like to call 'music'
  • Like 1
https://www.sau.com.au/forums/topic/356372-radelaide/#findComment-5702996
book in and do the coopers brewery tour. check out the coopers shop when you land at the airport they will give you the info. hire a car and drive to lobethal and go check out the lobethal brewhaus, top micro brewery
  • Like 1
https://www.sau.com.au/forums/topic/356372-radelaide/#findComment-5703003
Yes agreed , definitely make it to Harndorf , smash down some local Wurst with Beer yes.gif
Glenelg also Rundle street in the city check out the local spread , oh yeah !
Stay away from Hindley st in the city and the Northern suburbs. trololol
  • Like 1
  • Nope 1
https://www.sau.com.au/forums/topic/356372-radelaide/#findComment-5703091
Theres pretty much a Belgian Beer Bar in every city, I know melbourne has two - I wouldnt hit this up as something uniquelly south australian. If you can do a Coopers tour, do it. If you like wines, make your way to the Barossa, there are heaps of 'coach tours' so you dont have to drive :thumbsup:.
https://www.sau.com.au/forums/topic/356372-radelaide/#findComment-5703116
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
