Hey guys,
I recently bought myself a Stagea! It's in need of a service.
I've done a quick search and found a few part numbers for various pieces (which end up being useless, as there is no brand listed).
Anyway, I'm more interested in whether the listings for oil filters, spark plugs, fuel filter and all that jazz are the same as the Skylines? I know the belts, tensioners and waterpumps are interchangable across the RB engines (and I've already ordered these).
I don't see why they wouldn't be but I just wanted to make sure before I get everything together and find out that the threads are different on the Stagea RB or w/e.
Cheers,
Adam.
https://www.sau.com.au/forums/topic/356508-quick-servicing-question/
Depends on what Stagea you have. S1 is mainly R33 stuff and S2 R34. Only thing that is wildly different is the S1 ecu. Oh and the brakes are not turbo brakes! Engine, gearbox and diff pretty much the same as Skyline. And you can use the same quality synthetic atf for the gearbox, power steering and Attessa (if you have awd) - reservoir in rh side of boot.
Sorry, I was pretty vague!
I've got an S1.
Managed to figure out what I needed so all good :) I'll post part numbers up later, I can't remember them atm :closedeyes:
Not worried about the brakes or auto though, will be changed in a few months.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
