  • Replies 124
Next year should somehow put some money on the line! that'll make me not forget to me picks!
plenty of time to organize it and get more parties involved!
I would offer to donate some booze to the winner but laws ect in regards to that in case its a minor.. can't even give them a hat, oh well it can stay in my cupboard :nyaanyaa: especially this year with my 9 point lead (unless i really F* up the final round
1 RS 226
2 levinboy 216
3 N1GTR 214
4 stR33ter 212
5 nubs 206
6 SLOR 204
7 Beer Baron 201
8 lil-d-2 196
9 dezz 187
10 Roy 161
11 Krishy SAUSA 84
12 Snowman 56
13 Kozeyekan 19
Done for a year! Thanks to everyone that played
will arrange a league again next year, hopefully we can get more on to it (so if you have any friends into f1 feel free to invite them along)
Edited by Whiplash
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
