yeah im pretty sure i looked like the biggest twat today driving the m35 home for the first time and i was looking for the button or leaver to open the fuel flap. Only took me 20 minutes before i pushed it. OH!!! and WTF? $120 to fill up? 75L ? I had to check under the car and all around to make sure it wasn't all leaking out all over the floor.... The guy at the counter would have thought i was loosing my sh!t
Edited by loymclure
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
