Hey guys, i had the following installed today
Npc 5 puk button clutch
Nismo pivot ball
Brand new thrust bearing
Here's the problem... At most times in first gear or reverse just as im about to take off, i get a grinding noise coming from the gearbox area. However driving the car is normal at speed.
The other problem is the gearbox is whining under full throttle.. Im also down on power by a fair bit.
Flywheel has been machined, iv done a search but couldnt find the answer to my problem. Could it be a diff issue? The grinding issue started after the clutch change. The whining noise started when my OLD clutch started to slip and is still there after clutch change.
Can anyone help me?
https://www.sau.com.au/forums/topic/357018-clutch-changed-noisy-gearbox/
haha funnily enough im having this exact same issue, clutch changed, and now when say stopping at lights but before i stop n put into first, lights go green, so stay in second and keep going, i get a grinding noise from the gearbox region, same if i stay in second and go around a round about or something..
strange :S
You may have done what i did actidentally and have put the thrust bearing in backwards.
there is a right and wrong to put it in, i had to pull out the gearbox and get an new one.
Thanks for replies..
Grinding noise seems to be gone now... weird :blink:
BUT, still have the whining noise at full boost sometimes. I get loss of power and black smoke out the exhaust ONLY when i hear the whining noise, then a little idle dipping after i slow down. I think it's a boost leak.... What do you's think? I'll check all my piping and tighten everything up tomorrow.
Oh and the car is still making normal boost..... Just feels very low on power along with that annoying whine.
A leak in the intake can cause black smoke. I had a leak once where I spliced for my boost controller. I would shit out smoke like no tomorrow. All was normal when I fixed that up. It could also be the reason you get the idle dip when clutching in after boost, I had that same symptom.
The grinding noise could have been the clutch settling in. They say drive the car normal for about 100km then do a couple of clutch dumps. A freshly machined fly wheel will need to get the new clutch material on it.
As for the whine sound, every single R33 Ive sat in(and that is a few), if you listen closely they have a whine to them when the foot is off the clutch. If it gets louder when you are driving, there is some bearing which needs to be changed. Its not the throw out bearing(obviously) I think its the input shaft bearing. Don't worry about that whine, it will not be the cause of your power loss. Get it on a dyno and they will check it out. I'd prefer to pay $100 for an hour of dyno work to sus out a problem than $600 to get the box pulled out again and checked.
If you run a cheap short shifter, the noise will be amplified. If it wasn't for the amazingly short throw, I would have thrown my short shifter through someones window by now.
Edited by SargeRX8
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
