My car seems to be having some serious issues here
Was driving to the drags one evening and it suddenly just stopped working
(thank god it didnt happen on the drag strip)
It refused to start even when my friend helped me to jump start it
Towed it to the workshop and they told me they had spark but the injectors seems to be flooding the engine and the only thing they could think of is the ECU is ****ed. The workshop is going to be closed for the weekend so they said they'll test the ECU on monday
Recently before the incident Ive been having problems starting the car
sometimes I had to put some gas into it before it would crank over
and also a few days before I had a bosch 910 installed without a FPR
and exhaust cam gear set to 4Deg retard
So any ideas?
just incase it maters my car is a 1996 R33 Series II Auto
Here's the list of mods I currently have
S-AFCII
Profec B boost controller
Bosch 910 (no FPR)
HKS Exhaust Cam gear
Trust Cat-back
SS high flow cat
Front pipe
Trust V-SPL intercooler
Apexi Air Filter
cheers
https://www.sau.com.au/forums/topic/35704-engine-flooding-problem/
  • 1 month later...
I dont think you need a FPR...
Could be stuffed injector stuck open... be carely that you havent filled you cylinder/s with fuel and may have compression locked your motor .... pull the dip stick out and check to see if it smells like fuel??? It s not a common thing - but it does happen, trust me ;-<
Dan
Pump the throttle???
1. efi cars are ment to be started with the foot off of the throttle
2. would pumping the throttle actually do anything?? - its not like an old carby that opens up secondary squirters when pumped.
3. when you said you had a pump installed without a FPR, do you mean you removed the standatd/afrermarket FPR on the fuel reguator? if so why??
4. This may not explain why it flooded, but it indicates a few problems.
well it wont start with or without throttle
and the standard FPR is still there
When I installed the fuel pump my workshop said it might blow the standard FPR because of overpressure. How does that make sense? doesnt the FPR control the pressure?
IMACUL8:
checked out that possibility as well but its not compression lock
but havent checked the injectors though
If the engine is "flooded", you need to try and start with the "pedal to the metal" - this is to allow as much air as possible in to help ignite the fuel. DO NOT pump the throttle - that only adds "acceleration" fuel, and worsens the situation.
If the CAS was crook, you would not have spark.
I have been running the standard FPR in my 32 with a Bosch pump, and no problems encountered for nearly 2 years.
Can you hear the injectors working when trying to start the engine?
You are probably going to have to pull the injectors, so arrange to get them cleaned while they are out.
BACK ON THE ROAD!
turns out the CAS was electronically alive but mechanically dead!
and the little stick at the end of the cam shaft had snapped
oh well got HKS 256 in there now
when the engine is warm the cams are kinna noisy
is this normal?
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
