which bridge boiracer? there are 2,
1 @ pumicestone and th other @ williams ? but nah diddnt see it...damn!
prolly kaaned it and hit the grid lock line of cars, due to resurfacing that mess of tar they called a road..or the humps they leave when beveling off the tar ..they're some diff crunchers!!
one way traffic for 15 minute intervals at the mom... truly shocking! although good to re stack cd's and change tunes, lol
Just joined sau my pads near strathpine.
Car: R34GTT.
Colour: White.
Mods: Exhaust,19" rims,dumped on super low sup.
Plans for the next Mods:R34 RB26
Owned for:2 years
Other imports: 300zx TT
northside cruz sounds sweet, when and where?
Car: R34GTT.
Colour: White.
Owned for:2 years
We usually go to the pizza capers in the shopping centre on the corner of beams road and gympie road ( first right after the highway ends heading south)
sounds good but i cant make it tonight will try for next week, what time do you meet ?
hey guys,
i drive a black r32 gts-t
Stock as on a set of 18" rims and an exhaust, ive have the car about 8 months now cruising the caboolture area.
we meet up at the Carseldine shopping center (first traffic light after the bruce at beams road) most Thursday nights in front of pizza capers for the north side meetings but there hasn't been many ppl show up so far.
other than random hero and chris would like to see some more locals show their faces to make it more worthwhile. normally get there around 7:30 (ish) and have a bite to eat so if you feel like being social swing by :D
edit: oops wrong thread... how'd i manage that!?
Edited by mumslayer
Any one else have grief with ball joints and rear rack ends, I fix one, another goes, it's getting beyond annoying.
damn facking maintenance. My slug is still M.I.A
nah not yet mate. 45 thou km's and no issues. tie rod ends on the front are apparently a bit of an issue. 1 of mine is gettting to the point of needing replacing.
hey guys,
and you didnt mention me.....what am i?? swish cheese?? (no idea what that means)
havent posted my car up, but a few of you know it. White '96 R33 GTST, stocker than a rock. with Black onyx R33 GTR wheels.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
