I'm going to the hsv drive experience tomorrow. Work paid for it for me as i'm now the hsv specialist. Looking forward to thrashing other peoples cars ( hsv's cars) around a track for the day.
Make sure they give you one with a real transmission, not a lady's aid. Turn off the skid prevention, and remember that the magnetic ride control is a lie. It's just a placebo button! Then skid the shit outta that somebitch. If it catches on fire I want pics!
I am keen for Thursday night... I was like naww that was yesterday no wait Thursday is today... So yeah, I am keen for Carseldine!
Troy, Zane will be up this weekend :) So I might send you a text and we may pop over since I'm not working yippee...
Well skid pan was a skid fest. Had laid diesel down so max speed was 30k which was fast enough. Managed to drift over half the lap. Only one to.do so, must be the skyline training in me lol. Awesome day. Those guys can sure pedal a car.
lol, nice :)
I'm in for tonight!
Carseldine capers/ nando's it is! corner of beams road and the highway. you cant miss it :)
i'll be at the BP's on the highway in Morayfield at 7:15, and carseldine around 7:30
Sitting outside pizza capers.
did you send this just as i saw you turn up?? (you had a good "whos this creepy guy" look when i stared at you)
either way, good to meet you, and good to see Shane come out too. night wasn't too bad at all :thumbsup:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
