workingg sorry :( maybe on the weekend!! :P i have beers^^
my catback 3" is now on, 3" from cat, from the hotdog it goes 3.25 with a cannon all in one, thanks to an sau member simdog. Nice and cheap and affordable for my budget. now ill just have to wait a week or 2 to order my jjr front dump and catco cat converter!!
Last of my spendings as the new house is gonna make me poor
http://www.ebay.com....=item58938e8e60
this is what i got....but i payed less :P
and yeah ive been looking at just getting the catco one. other car related expenses have come up atm. so it may be a little while for me :(
I feel like a drive. where? may grab a westie or two as well.
yeah im keen, only just got home and need a shower etc first, but am keen to head westies way :)
you bringing the 31 out chris? wanna meet at carseldine for the drive? or just meet down there?
lol, i assume so.....either that or my dad. but none of you have met him....so thats very unlikely.
changed the plugs in my car yesterday arvo. and had a look at my coilpacks.......theyre all white and burnt on the outside :P...fun fun.
So i gave em a soaking in silicone and some fresh tape, and get ready to buy new ones as soon as rego and insurance time passes. turns out the Iridiums that were in it are gapped to 0.8 despite the fact that the box says 1.1.......and honestly dont know if i did it myself it was that long ago.
So coppers with a 0.8 gap, and a bandaid on the coils and my stutter is gone! just a mild flatspot left around 4500...but that i would assume is the burnt out old coils.
and today i spend cleaning my car inside out........farrrk i hate Bitumen.....
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
