rebuild an old car yourself, that's sooo fulfilling.
on another note, im out for thursday. Maureen is gonna be gone all weekend and im gonna spend the night with her.
and on that point an thinking about doing a bit of a LAN downstairs in my house over the weekend :)
well to be honest, i'm doing some work experiences at a panel beater that restores old minis, and am currently restoring one, as for lan, i would if my computer hadn't have been totally F**KED over by my uncle, need to spend at least a grand on it to get it back to the way it was, so is on the to do list
Hey guys,
Just wondering if any of you know a good place around the Bribie Island & Caboolture area to get a body kit fitted and painted.Got a kit from DMD the other day and also have a bit of wheel arch rust to get fixed at the time time.
Looking to get both done at the same time. Any help greatly appreciated
Thanks in advance, Scotty !
all good man, LAN isnt happening anyways, due to the SAU cruise being on Saturday (which i previously thought was on sunday).
having drinks and video games at home just tomorrow arvo/night instead if anyones keen.
Hey guys,
no idea to be honest man, the only panel shop ive ever had anything to do with doesn't exists anymore.
What games are you playing at this LAN?
Hey guys,
Hey mate,
I know a bloke who might fit and paint the kit and would be able to fix the rust spots, the only catch is that he is in northgate, but I know you would be able to get it booked in fairly early
did you buy your minecraft Bodo?
yes indeed, been a few years now, got it while it was still alpha. with the promise of free updates forever!! lol think it was about $15....havent played it much in the last few months.
if you get into it, you should join Ben's server. we got some serious building going on therre
Full 3" Exhaust
FMIC
Vipec ECU
Boost Controller
Think thats it
Ive got some 740cc injectors at home to put in with the turbo, hoping for over 260rwkw
I brought a SS1PU for my 34, I am making about that power figure now mine has:
600cc injectors
z32 afm
full 3" exhaust
hypergear ss1pu
Hybrid FMIC
Apexi Power FC
Gizmo boost controller.
tuned on 17 psi
The big thing to keep in mind is that the stock head gasket can only take so much before it will crap out hence the low boost on mine, it came with the actuator set for 21 psi.
600cc injectors
z32 afm
full 3" exhaust
hypergear ss1pu
Hybrid FMIC
Apexi Power FC
tuned on 17 psi
I was going to get the SS1PU originally, just changed my mind at the last minute to the SS2. Whats your thoughts about going to a highmonted setup. Im undecided whether to stick with the low mount of shell out and get a highmount manifold.
Are you rolling stock plenum?
Yeah still rolling stock plenum atm, looking at grabbing a front facing, water meth and Cam's next
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
