rebuild an old car yourself, that's sooo fulfilling.
on another note, im out for thursday. Maureen is gonna be gone all weekend and im gonna spend the night with her.
and on that point an thinking about doing a bit of a LAN downstairs in my house over the weekend :)
well to be honest, i'm doing some work experiences at a panel beater that restores old minis, and am currently restoring one, as for lan, i would if my computer hadn't have been totally F**KED over by my uncle, need to spend at least a grand on it to get it back to the way it was, so is on the to do list
Hey guys,
Just wondering if any of you know a good place around the Bribie Island & Caboolture area to get a body kit fitted and painted.Got a kit from DMD the other day and also have a bit of wheel arch rust to get fixed at the time time.
Looking to get both done at the same time. Any help greatly appreciated
Thanks in advance, Scotty !
all good man, LAN isnt happening anyways, due to the SAU cruise being on Saturday (which i previously thought was on sunday).
having drinks and video games at home just tomorrow arvo/night instead if anyones keen.
Hey guys,
no idea to be honest man, the only panel shop ive ever had anything to do with doesn't exists anymore.
What games are you playing at this LAN?
Hey guys,
Hey mate,
I know a bloke who might fit and paint the kit and would be able to fix the rust spots, the only catch is that he is in northgate, but I know you would be able to get it booked in fairly early
did you buy your minecraft Bodo?
yes indeed, been a few years now, got it while it was still alpha. with the promise of free updates forever!! lol think it was about $15....havent played it much in the last few months.
if you get into it, you should join Ben's server. we got some serious building going on therre
Full 3" Exhaust
FMIC
Vipec ECU
Boost Controller
Think thats it
Ive got some 740cc injectors at home to put in with the turbo, hoping for over 260rwkw
I brought a SS1PU for my 34, I am making about that power figure now mine has:
600cc injectors
z32 afm
full 3" exhaust
hypergear ss1pu
Hybrid FMIC
Apexi Power FC
Gizmo boost controller.
tuned on 17 psi
The big thing to keep in mind is that the stock head gasket can only take so much before it will crap out hence the low boost on mine, it came with the actuator set for 21 psi.
600cc injectors
z32 afm
full 3" exhaust
hypergear ss1pu
Hybrid FMIC
Apexi Power FC
tuned on 17 psi
I was going to get the SS1PU originally, just changed my mind at the last minute to the SS2. Whats your thoughts about going to a highmonted setup. Im undecided whether to stick with the low mount of shell out and get a highmount manifold.
Are you rolling stock plenum?
Yeah still rolling stock plenum atm, looking at grabbing a front facing, water meth and Cam's next
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
