It makes no sense
No sense, NONSENSE I tells ya...
But srs why not come over to this whore town, talk crap (for free mind you) get more people interested and be easier to access... Some people
I see your Wife getting around in the beatle nearly every morning on my way to work now, She had your skyline the other day.
You could always come visit me if you miss me that much.
So...My supposedly top notch custom heavy duty clutch that is just over a year old (sub 5000k's) is already nearly worn out... took it for a drive today and noticed that my clutch engages half way up the pedal.
I will be adding that to the list of stuff to replace in July.
Yup on her way to work in Clonarf. She had my car for a few days, as hers was getting a new carby and tuning.
I have been meaning to come and say g'day
And how is the upper north Brissy?
same old same old
Same as normal, needs more mountain runs.
this
Thats lame, What brand is it? and i assume you have checked clutch fluid lvls? not that its leaking everywhere.
Drop me a message or a call and come up for a beer man check out the new digs.
It was custom built by RPM, I don't think it is a fluid issue.
Edited by RandomHero83
its not...... Its pretty much purchase by the Drum. Sucrogen E85 is what it will be running on. Long story short, getting a Haltech sensor installed in fuel line which can sense the blend of fuel so i can run either E85 or 98 pump. Even a mix of both, then the ecu will adjust the tune accordingly
That's pretty cool and probably more manageable as well. How much of a power difference is there between the E85 & 98 for you?
if i get a 15% power increase ill be happy.
What Power is it running now and what have you done with it since last I viewed the forum?
makes 350hp, havent changed much.
Still Internally gated GT3076,low mounted
ViPEC ecu
740cc injectors,
4" Cold Air intake
Upgraded cams
APR Headstuds & Metal Head Gasket
Heads been rebuilt
Full 3" exhaust
Probably a few more things i cant thing of at 545am..
Ill be happy if i can break through the 400hp mark
ViPEC ecu
740cc injectors,
4" Cold Air intake
Upgraded cams
Heads been rebuilt
Full 3" exhaust
Yeah in July mine is going to a new shop to break the 400 mark, I'd say it will be back in for a new brand name clutch and a metal head gasket not long after if not during
Get video footage of the Kaboom?
I Like it in here......Whoretown goes far to fast, It's been 3 pages since my last post and from what i can tell its all about how many posts we have...lol. Bunch of Nerds over there :whistling:
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
