TA DA!
sort of......It all went on well, other than the last corner over the passenger headlight, where it peeled the shit out of the paint underneath and ruined it. :verymad: gonna try and fix it. Or just tear it off and start again.
Repeaters, driving lights and indicators all smoked looks much better than those big orange dots :yes:
Mumslayer has joined the mothersite!
dont expect much however with the closing of the national i have been forced back here :D
any way to change the white background like you could with sauqld? too much white
tinted lights look good. What did you use?
BTW picked up the car Friday and back on the road. Ended up getting a NPC single plate button clutch. Alot different to my old Excedy H/D clutch.
Edited by SCR48
Just gor pulled over by cops in my mates supra and gave him about his steering wheel.for no padding so I guess question is he is the first owner in australia and it was complied with the steering wheel attached is it illegal?
What about all performance exhaust being defectable? The cop tried saying that they are and they could defect you and make you get a stock one installed. Im assuming they would only be illegal if it made it make more the the legal dB limit or didnt stop emissions properly like high flow/ decat or dump pipe.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
