TA DA!
sort of......It all went on well, other than the last corner over the passenger headlight, where it peeled the shit out of the paint underneath and ruined it. :verymad: gonna try and fix it. Or just tear it off and start again.
Repeaters, driving lights and indicators all smoked looks much better than those big orange dots :yes:
Mumslayer has joined the mothersite!
dont expect much however with the closing of the national i have been forced back here :D
any way to change the white background like you could with sauqld? too much white
tinted lights look good. What did you use?
BTW picked up the car Friday and back on the road. Ended up getting a NPC single plate button clutch. Alot different to my old Excedy H/D clutch.
Edited by SCR48
Just gor pulled over by cops in my mates supra and gave him about his steering wheel.for no padding so I guess question is he is the first owner in australia and it was complied with the steering wheel attached is it illegal?
What about all performance exhaust being defectable? The cop tried saying that they are and they could defect you and make you get a stock one installed. Im assuming they would only be illegal if it made it make more the the legal dB limit or didnt stop emissions properly like high flow/ decat or dump pipe.
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
