I just wanted to touch on that horsepower thing the other guy was talking about.....I was doing a little thinking about the horse, the rope and the weight etc. Does the weight of the rope enter into the equation and could the 1.8hp horse actually be using a lighter rope and therefore 'generous dyno'???
https://www.sau.com.au/forums/topic/357541-sorry-nismoid-i-wasnt-finished/
  • Replies 62
Posted Images
What if you stuffed said rope down horses spark plug hole. Would that up the c/r enough to make one horse a two horsepower horse.
wtf Noel! The rope is going to reduce the cc capacity of the chamber, in turn, reducing it's volumetric gallop ratio
Did you like the explanation of the history of the word boost. I thought it was pretty good.
As far as a generous dyno goes the weight of the rope is a constant. Dynos have to use the same grade rope. There will be some differences in the weight between the rope, the two main rope manufacturers of the day sourced their twine from different sides of the country, and there was some density difference, but this was so small that the weight difference is negligible compared to the weight of the mass.
That is not to say that generous dyno's didn't exist, because they did. When the horse did a "pull" on the dyno there was a person who had to count the revolutions of the sheave in a 30 second period if this guy got the count wrong by a rev or two that could put out the actual HP reading, Wetheringtons Horse Dyno Service was notorious for this as they used to employ the cheapest dyno operators who usually had trouble counting, giving a false reading.
Edited by robincooper
Were they located in Perth?
Who? Wetheringtons? The first Wetheringtons was a mobile service that went around to all the goldfields in Victoria so the miners could have their horses dynoed before they bought/sold a horse. The guy who had the mobile service, Arthur Wetherington later set up a workshop in Bendigo which was a great success. The business model was then franchised out to different people and I believe for a short while there was a Wetheringtons franchise in Perth.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
