Chris, this unit has a DVD player in the boot which uses the xanavi Cd to use the Navigation unit.
Makes me wonder that if i replace the DVD player and buy a whole new in dash system with navi, i could prolly use the the same brackets / wiring and wont have to do whte whole thing over. agree?
it has a satellite thing that sits on the dashboard.
  • Replies 72
Posted Images
WOW GUYS GUESS WHAT!?!? Just then on my drive, I turned the ignition, decided to press the open button (I do this everytime I go for a drive) and this time, the head unit opened!!!! It was amazing, it worked for about 2 minutes, the CD player too!! The CD player I left in there it went off for sure!! I heard a subwoofer at the back which I didn't know if it still worked, maxed out the speakers for those 2 minutes, then all of a sudden, it went dead, nothing displayed on the screen and the CD player didnt work anymore... WHY is this so? Connection problems? Should I take it apart and rewire the connections!?
more photos for my system
i was thinking of getting something like this done. though im not sure who around tiny geelong would. Probably JB hi-fi, but i don't want to go ask for a quote till i have the dosh ready.
http://www.youtube.com/user/mightycarmods#p/search/6/lTuMWxzrMHE
If any of you have any links to good cheap systems / know anywhere around this side of melbourne / vic that would do stuff like this pls let me know.
thanks
If you need a replacement of those units in your dash, I've got the lot for sale lol.
It's from a R34 GTR, but I think it should be exactly the same? Also have a boot carpet with a factory CD stacker, and lastly a din pocket with lid lol.
another question
I was watching Top gear (s01e04) where they review R34's. They show that the screen in car shows the onboard computer logistics as they drive. is this possible for all r34's or whats the deal?
Yup, it's definitely possible, many people have that conversion.
Turbo or NA, both works, it's just that if you put it into an NA, it will only show throttle, rev light, oil temp, injectors, voltage.
But a MFD (multi function display) is costly, can cost anywhere between $600-$1000. I just sold one without looms for $600.
Here's a pic of my R34 GTT interior.
I have the same setup as grey in my skyline, is it possible to just change the pop up screen to like a GPS or something.. i also went to JB HI-FI and they said they can change the head unit and put a new frame and that for just over a $100 is that worth it ?
gotta love these people that think cheap is the way to go. its not. to do it correctly it is a AC controller swap,panel swap and then a screen swap.
that screen is data driven and has to see data from the navi system first BEFORE it will fire up. without the navi system its just about useless.
I have one to do on thursday and I will post a few pics up on the shop facebook page.
i dont really care about the screen or nav system that came with it, was just wondering if i got rid of whats in there already could i replace it with something else
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
