"Get a hiflow turbo, GCG or Hypergear etc. Not to mention these will just bolt straight back on plus the fact they have factory appearance and about half the price of a HKS kit. Just saying this has all been discussed over and over before. So much info on here. "
Hypergear Plain Bearing Hiflow ~$1000
Cheapish Injectors ~$400
Z32 AFM $350
Just Jap 3" Dump Pipe $200
Hi flow cat and Catback not sure say $600
Intake Pipe $150-300
Plus Install
Nistune install and tune $1000
I reckon you could get 250rwkw going for a bit over $4k ish if you were careful and did some things yourself. Although when does the auto need strengthening?
$6-7 would be more a garrett turbo installed which you could push more than 250rwkw if you wanted.
  • Replies 63
Thanks for the prices you listed above,even though they are only a guess or roughly.
All those above things would get me around 250kWs at the wheels or engine ? What do you mean when does the auto transmission need strengthening ?
How much power can a stock auto gearbox handle ? Do you know or does anyone know ?
Thanks !
Yes it will handle 250rwkw but it would benefit hugely from a basic shift kit (even just doing the welsh plugs). I got a guy down in Bibra Lake to do mine (Global Auto Trans or something like that), cheap as and made a HUGE difference.
For an auto 34GTT, NIStune is pretty much the only option. As the TCM is part of the ECU, you need to wire any standalone in as a piggyback (that's how my Haltech has been wired up) otherwise you'll be driving around in 3rd gear everywhere :)
what do they do or install exactly and how much does it cost ?
do you happen to live around Canning Vale ? Saw one Stagea exactly like yours,silver,wagon etc. License 1BWO or 1 BOW or something haha
If not then don't worry.
Yeah,I understand.What's a GTRS bolt on kit and where can I find more information about it ?
And is nitrous oxide even legal to use on a car ?
Maybe I should for the Nistune first then (to make around 200kWs) ?
have bought in afew GT-RS kits for fellow wa members, all of them seem to get around the 300-350rwhp mark.
Good turbo, comes in a BOLT-ON kit basically has everything you need to bolt it on.
It sits in the factory turbo position so when you open the bonnet it will just look like the std turbo does now.
i 100% recommend them however at the current exchange rate you will be looking between $3000-$4000 ship if i remember right.
If you need more info just ask, i also help installed the last one i got, very easy took half a day
Okay,cool.Are there any other cheaper options that I can look at then ?
I mean $7,000 just to get 250kWs isn't worth it.If it cost $7,000 just to make 250kWs,how much would it cost to make around 300-500kWs ?
Hahaha
horsepower cost money.
If you get the right supporting mods it is easy to upgrade your turbo to something bigger later on.
The main parts which you can't really cheap out on are
1. Fuel Pump
~Nismo or similar all make a bolt in fuel pump
$300-$400
2. Injectors
~Nismo or sard
$500-$1000
3. Afm
~Z32
$200-$400
4. Ecu
~Nistune
referring back to the original pot, You CAN use a Haltech with the stock ECU, you will need a Haltech Platinum Interceptor $799 retail, these only control apark and fuel basically, just a piggy back.
otherwise get a nistune
Cost me less than $200 and they basically removed the accumulator pistons on the 1-2 and 2-3 shifts (there is a chamber with a sprung piston to dampen oil flow) and replaced with 50mm welsh plugs.. ergo no dampening!
And nope, not me :)
1. Fuel Pump
$300-$400
2. Injectors
~Nismo or sard
$500-$1000
3. Afm
~Z32
$200-$400
4. Ecu
~Nistune
Fuel pump, I'm a fan of Bosch units. Mount an 044 intank FTW.
Injectors, stockers will see you to about 230rwkw. If you need bigger, look in the Group Buy area for the Siemens Deka injectors. Unfortunately with Neo engines, we are very limited with injector upgrades :(
Z32 AFM, needed as the stocker will max out pretty early.
ECU, NIStune should be able to get a board fitted and tuned for well under $800. Don't waste your time with anything else, simply not worth it.
Turbo, I'm running a massive highflow of unknown specs (came with the car), Hypergear do a bolt-on highflow good for ~260rwkw and only costs about $1000. Bolts up to EVERYTHING just like standard.
Just get a NIStune. My wagon is running a Haltech e11v2, wonderful ECU.. if the wagon was a race car.. terrible for an auto street car.
Edited by bubba
Yeah,I've looking at that.You're talking about the Hypergear High Flow Turbo right ?
Are you located here in Perth or another state ?
300-350HP ? What to do to get 350HP,I mean not between 300-350HP ?
Kaido was talking about a HKS kit.
350hp is 260kw. To get there you would need z32 afm, bigger injectors, fuel pump, turbo and NIStune. Oh and a full 3" exhaust.
You seem like a nice guy :) hehe.
So.....what's the first thing I should do to my car ?
I'm not sure,should I get the bolt-on turbo kit straight away or do the Nistune ECU,exhaust,headers,fuel pump etc. first ??
Edited by Jeremy1607
You need the nistune before you up grade the turbo, you need the nistune before you upgrade the injectors, you need the nistune before you upgrade the afm... Ect.
Okay,cool.Then I will get the Nistune fitted and tuned first then.
Thanks !
Just to clarify something, "headers" aren't really an upgrade for turbo cars as it's not as simple as bolting on a set of extractors and off you go.
The standard exhaust manifold is good for up around 300rwkw and generally an aftermarket exhaust manifold is used for a big turbo with an external wastegate.
Your first port of call should be a decent fuel pump and a full, turbo-back exhaust, boost tee (or electronic boost controller) then NIStune and a tune. That should net you close to 200rwkw and you can get used to driving it with some more power. By that stage you'll be needing to get the minor shift kit in to the auto and then you can look for a turbo upgrade.
I can take you for a ride in the wagon if you want, for all intents and purposes the engine is a 34GTT setup, it's just a bit heavier and is 4WD when I want it to be :)
Edited by bubba
best to do everything at once.
But ecu(nistune), aftermarket injectors, z32 then get a tune
Not necessarily, he won't max either the stock injectors or afm with the stock turbo so not much point splashing coin when it isn't needed.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
