Hi All,
I have a Blitz Active type twin plate clutch for sale, it is a push type.
It can be used as a single or twin plate clutch as i found out after I had installed the new single in my car.
It has been in my car for three years and done less than 5000km of city driving and has never been tracked.
I am asking $2000ono as it cost me $3000 when i bought it.
It comes with clutch, bearing carrier, thrust bearing and flywheel bolts.
https://www.sau.com.au/forums/topic/357605-blitz-active-clutch-twin-plate/
Another price drop $1500, htere must be a tough R32 GTR or GTST looking for a clutch out there.
I will pull it apart and take photos for the wear soon.
  • 4 weeks later...
Price drop to $1200 ono, this is now a bargain as it has done no work at all and was built to be abused.
Should mention this is a full set up with its own flywheel and all.
Only reason for pulling this out was not enjoyable in crawling peak hour and
put a single in to make it easily daily driveable and so the wife could drive
the car too.
It was great in flowing traffic and never gave me any issues at all.
Great for someone that wants to go to the track with there car and wants
something guaranteed to stand up to abuse.
Thanks Beer as it helps my cause to sell this clutch when somebody else
also give it the vote of confidence.
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
