For Sale.
Trust Profec B Spec 2
With solenoid and harness
$370 posted anywhere in Australia
Turbosmart Ultragate 38mm
As new- used for 2 dyno runs.
Still in original box with all fittings etc.
$450 posted anywhere in Australia
The above parts were removed as I have returned the car back to stock.
Thanks
Located in Bunbury WA
0409117081
https://www.sau.com.au/forums/topic/357615-profec-b-38mm-turbosmart-gate/
  • 3 weeks later...
