  • Replies 184
Posted Images
I've got one in the car, won't be using it, need to use the T56 slave cylinder.
Only issue is, it's at Brads in the car still.
You'll have to get there and unbolt it (Without pissing brad off on me, or dirtying the workshop :P )
Edit: Also make sure it's okay with Brad and doesn't muck up any of his plans...
haha all good matt and thanks! - will see what steve-o can do first, and the cost of the bore and new piston for modifying the stocker.
o0o0o t56 6 speed hey - hydrolic thrust engagement changes things up a bit
Having never driven on semi slicks before - do they have alot of road noise? like a whine sort of noise?
hope its just the tyres lol
either that or the 2 way is transfering alot of noise/vibration with the urethane bushes in the complete cradle
Chris, what was the need for having the slave bored out bigger? I know you need more fluid to be moved... Is it just because the friction point is too close to the floor? Cause you can alter this...
Edit: Just re-read and had a brain fart of a late night thought, had an epic long rambling post written... Then realised I was talking about the master cylinder not the slave...
I still have the Slave cylinder if you need it. Just speak with Brad in regards to grabbing it.
Oh, I also got those parts too, just need to fit them. Thanks heaps!
hahaha no problem, yeah bigger slave to lighten the pedal feel
will chat to the shop that did the brake kit and see how much it cost, we had that done to the 1jz 5 speed slave in the sprinter but i dont remember the costs.
Cable system FTW!!!!
haha what?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
