Yeah true but does it look as aggressive? without the caps.
Guess it depends on what look you want.
Mine did not come with centre caps.
Still I think it will just look 'neater' / 'complete' with them on.
TE37 with Flat Centre cap.
TE37 with VOLK Centre cap.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
