Yea thanks for that will try for larger photos
As you could imagine a First year apprentice loosing his car is a major blow so all help appreciated.
yeah, no joke. hope it turns up un-molested.
in before the standard non-helpfull questions, so i'll ask them
1) is it insured?
2) does it have an alarm?
3) something else?
https://www.sau.com.au/forums/topic/357783-stolen-r33/#findComment-5718345
Yea non turbo 4 stud wheels
i know its no consolation but because of that it hopefully will turn up unmolested at a NA isn't as fast or as much fun as a turbo lets hope the thieves don't get angry at it for not being turbo
https://www.sau.com.au/forums/topic/357783-stolen-r33/#findComment-5718439
Hi Guys
The car is still missing, can you please keep an eye out, I have found the for sale link, the paint is bad on it so should make it easy to spot someone has tried to respray it with clear coat so it has massive runs along the sides
Here is the link http://www.skylinesaustralia.com/forums/topic/354186-for-sale-thread/page__view__findpost__p__5608366
All help appreciated if you see it please call the police or i can be contacted on 0403170893
Thanks in advance Devo
The post is 5395
Edited by DEVO R33GTR
https://www.sau.com.au/forums/topic/357783-stolen-r33/#findComment-5724102
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
