yeh can someone buy it? i definitely want someone to actually use it rather than it collect dust and space in scotts garage! im sure he'd agree about the space!
Price is Negotiable!!!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
