  • Replies 61
Tyson from the 31 club's car has been stolen
SVD052
If seen, call me 0466690620, or tyson on 0432664926
was stolen 10 mins ago from City CBD.
was last seen headed south on Pulteney st from the ale house.
That sucks! gorgeous SVD that... I'll keep my eyes peeled
-D
https://www.sau.com.au/forums/topic/358003-stolen-r31-gts1/#findComment-5721189
If anyone knows anyone that does dispatch for any taxi/security/whateverelseyoucanthinkof, if you could give them a call and pass on the rego number and a description of the car, that would be pretty handy.
https://www.sau.com.au/forums/topic/358003-stolen-r31-gts1/#findComment-5721366
+1 ive got my eyes open, it looks like a sweet example of a 31.
I to am sorry to hear its been nicked. I hope it comes back in 1 peice.
Frikkin sickins me to see all these imports targeted, there is no respet fo peoples time and effort that have been put into these cars. :down:
https://www.sau.com.au/forums/topic/358003-stolen-r31-gts1/#findComment-5721741
dang we would have a motor sport park tomorrow also :D would build 3 new prisons to house all these car theives but hey get em off the streets :D
also bring back hard labour for prisons if i have to get up @ 5:30 and work so should they
https://www.sau.com.au/forums/topic/358003-stolen-r31-gts1/#findComment-5721935
gav, word is out amongst the breakdown boys around the place. if a truck sees it they'll be radio'ing it in
i recommend if anyone sees it, attempt a follow. its a stupidly quick car, and i dont doubt that a pit manouvre would be approved by its owner to get it back in one piece
if i hadnt had to work today, i woulda been out around the north area on the lookout for it
https://www.sau.com.au/forums/topic/358003-stolen-r31-gts1/#findComment-5722228
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
