Hi all
A lot of you will know that all too familiar sound when the bearings in your turbo decide to slowly seize up. I knew my car wasn't running well on the "Children of the Dark" crusie but I didn't think it was this terminal.
Anyway, after a couple of days reading forums I think I've got the following options:-
1) Rebuild the original turbo (going to Per4manz or otherwise)
2) Get a replacement 2nd hand stock item
3) Second hand used item other than stock (HKS 2530/2535 or similar)
4) New turbo
5) Send to CGC for highflow of original.
Basically, I don't want to have to bother with new tubular manifolds or the like and would rather something that bolts into the stock location. Oil and water lines can be made if necessary as can dump/front pipes.
What would you all recommend. Budget is $2,500 absolute tops. (I've just spent $4K on rebuild so I'm strapped for cash). Car is R33 S2 with FMIC, clutch, 910 fuel pump, S-AFCII, EBC and forged pistons.
If anyone is suggesting new turbo, any suggestions where in Perth?
Cheers!
Dave
https://www.sau.com.au/forums/topic/35814-its-turbo-time/
  • Replies 52
Rumour has it that turbo tech have ball bearing balancer? maybe you wont have to send to cgc to get it high flowed as ballbearing still? to Hi flow yours in perth, with plain bearing, will cost you about 1300 bux, leaves some money to spend elsewhere in car or in life. This turbo on your set up should see around 330 rwhp on about 1 bar.
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-714848
speak to grant at per4manz about hiflowing your original turbo with sierra internals!!! YEEEEAAAAHH!! sierra internals are abou the biggest that can fit in our turbo... quite nice reallly ... thats what i got on my puppy and works a treat... ask skyzer and mrsnrub (ben) how my turbo goes, grant did a great job for the money i spent and am well happy.
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-714974
KamikazeR33: PM Replied. Sorry!
Everyone else, a summary
Rebuild/Replace stock turbo in WA with thrust bearing turbo: $1300 +
Order new HKS turbo from Japan (greenline/takas/nengun etc) :$2000+
Order new standard turbo from Nissan: $1800 ish
Highflow stock unit by GCG: $1950 + shipping each way (450HP Stage 1)
What do you all think?
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-715858
per4manz turbos do a t3/t4 brand new for $2000-$2200, bolt on to standard dump and manafold, no mods to oil lines. at one bar looking at around 350rwhp with better midrange response than stock. iv just fitted mine and should be getting tune next week.
when comparing to a hks say 2530 its around same price as a second hand, flows more and is a bolt on fit.
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-716315
am running 314 with bugger all timing added there is heaps to be added as i have forgies in there now... thats next time at SST plus Cam Gear is out.... way out... i would say around 340 rwhp to 350 rwhp should be achieved.....at about 17 psi.... all in all quite happy with it....
if money conscious then go the sierra hi flow......yummmm bit bigger than t3 t4 and sounds the goods too :-) can't remember how much grant charges but find out and speak to him before ya do anything 1st...
I;m trying to buy a crap car around 1g to drive to mt lawley zest.... if i can find one then i will start putting money aside for a nice plenum and so on and so forth... plenum i think would go nicely with my turbo ;-)
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-716403
Ok now you can go and do something a bit more respectable down at the drags to further sell the story of the new found power :) 314rwhp should get you a nice mid 12, especially if the turbo is gutsy in the mid range.
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-716465
GT25R has T25 flange right? Also, who in Perth sell them? Or is that another net purchase?
Thanks for all the replies. Rob77, I'll take you up on the offer one day too, would love a ride in your car. At the moment I'm leaning toward the HKS2530 option but obviously open to the Garrett equivalent. I'm trying to get a straight answer from someone as to how "bolt on" an HKS turbo really is. (ie does the dump pipe match up, pipe to AFM, pipe to cooler, oil + water lines)
I'm a little hesitant to go back to thrust bearing cause i know I like the instant response of my current ball bearing unit. It's probably being fussy but that's just me :D
Dan, no worries on threadjack and thanks for info on Per4manz turbo option. Maybe i'll need a wrap in your car too :)
https://www.sau.com.au/forums/topic/35814-its-turbo-time/#findComment-716470
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
