  • Replies 151
Posted Images
lol, Gold!
i remember seeing some hotties in kimono's on an Ignition DVD segment on an SAU cruise, think it was the 25th anniversary of the 32 or something. Why dont we get those everytime? except at the next one they rip the traditional get up off halfway through the lunch break and dive into the jelly/chocolate pool...
:banana:
