Hey Guyz, Im selling few of my parts off my R34 GTT because i need money to clear a defect,
1] Tein Super Street Coilovers- These are height and damper adjustable and are great for the street as well as the track..These have been in my Car for around 10k km's and they run perfectly fine, run straight and have no rust at all, Im selling it for $1200.. Need stock suspension for R34 GTT, will swap+Cash my way!!
2] Gmax 18inch Rims- They are 8.5" wide in the front and 9.5" wide for the rear, the fit perfectly into the gaurds of an R34 or r33 and look amazing, They have Kumho Ku36's in the front with around 40% tread and rear's have Zeta's with around 60% tread... The fronts are 235/40/18 and the rear's are 235/40/18.. Selling for $1400, Need stock rims of any kind will swap+cash my way!!
This is how they look on my car, They have a good dish on the rears..
3] R34 GTT Rear Spolier/Wing- Im selling my spolier which is black in colour its in perfect condtion with no scratches or marks, it is black in colour, Im selling it for $200
4] R34 Nismo Aero Side skirts- Im selling my side skirts off my R34 which are in great condtion with no cracks or anything, Its black in colour and ready to bolton. Im selling it for $350
I live in the northern suburbs of Melbourne and only accept local pickup...
Cheers!!
https://www.sau.com.au/forums/topic/358238-r34-gtt-partsmelbourne/
Hey i bought the coilovers from new and the top mounts are all there to adjust damper settings on the coilover, Its in perfect condition and comes with everything that the coilover comes with, Even the C spanners!!
Yea and you can get Tein Super street Coilovers for $1900 new, By the sound of it You clearly dont know the difference between Tein and BC Coilovers, Go do your research my Friend!!
i know about Tein coilovers i use to fit them in cars when i worked at jshop perth.
they are good but there is better out there.
i was just saying i would not pay 1k for second hand when u can get some new for 1200.
its not going to be a track car just a nice streeter that rides nice not to harsh
Well thank you for ur Non-valuable input to this thread, if you dont want to buy, then Why even comment? Go increase your posts at other places!! And since you can get them for 1200 new i suggest you go and buy them then!!
And since there are better out there why dont you just go buy the best!!
Just bought the same coilovers second hand from a guy and they are well worth $1000 all day long as long as they havnt been mistreated or abused which these don't look like they have yes you can get bc coilovers new for $1200 but they are made in TAIWAN not JAPAN like tein coilovers nothing beats them for the money good luck with the sale mate.there will always be haters.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
