I know its been spoken many times before, But I havent seen any referance to this.. so thought you might like to have a little look and comment on if you think it would work,
it says stagea there...
http://translate.google.com.au/translate?hl=en&sl=ja&u=http://www.rakuten.ne.jp/gold/naniwaya/bosr/option/option_cancelar.htm
been finding heeps of goodies recently on the net, like eyelids and such..
https://www.sau.com.au/forums/topic/358286-airbag-light/
dont quote me, but if the system finds a fault, no airbag will deploy in the event of an accident.
therefore, no error lights will deploy the required airbag (assuming you have one connected).
so putting the resistor in the place of the airbag will stop the fault code and the system will act 'normally'
https://www.sau.com.au/forums/topic/358286-airbag-light/#findComment-5724967
That would be my understanding also; obviously if theres no sensors other than the ones in the seat - then the bags will never go off if you've put a resistor in its place.
https://www.sau.com.au/forums/topic/358286-airbag-light/#findComment-5725002
i dont think there is a sensor in the seat
its a ram that tilts the seat backwards........ i think
for people with the safetly pack, there are bags in the ouside edge of the seat too.
I've got one sitting on my desk at home, I havent the foggiest idea how it operates - I assumed it was a sensor of some description (the warning on it is DO NOT DROP so I figured it worked as G/shock Sensor), but it could well tilt the seat in the event of a crash. I'll take some photos of it tonight
https://www.sau.com.au/forums/topic/358286-airbag-light/#findComment-5725058
Here's my understanding of this after lots of research & trying various "solutions".
The ram/s under the seats are to stop submarining in the event of an accident. They could tilt the seat as Iain suggested or, as I'm led to believe, push the front foam cushion up under your thighs to stop you sliding forward into the footwell. Same result in the end. I can't actually tell physically where they live under the seat since mine are gone & I just have the yellow connectors swinging in the breeze.
The fix that has worked on some cars (notably GTRs) was for a 2.2 ohm resistor, but this thread http://www.skylinesaustralia.com/forums/St...ht-t340591.html shows guys going for this u-turn harness http://gt-rr.com/pro..._harness&id=761.
I actually bought these ones http://www.tunersgro...rn_harness.html for my M35. They even took exact details of my car to make sure of compatibility.
The interesting thing is they don't show up any resistance when measured with a mutimeter......
The result? Nothing worked in my case :mad: , but I would be happy to send the Works Bell u-turn harnesses to anyone who wishes to try them out.
I'm still waiting on a spare SRS module from some guy with a wrecked one, just to see if my problem is bigger than the harness can fix.
https://www.sau.com.au/forums/topic/358286-airbag-light/#findComment-5725111
i think you mean you plugged it in :P
on my electric seats, there is a clip holding the yellow plug into the back of the ram. looks like it can pop off easily. pull your seats out guys, might be a simple fix like above!!
https://www.sau.com.au/forums/topic/358286-airbag-light/#findComment-5727299
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
