Hi all
I've been vaguely thinking about upgrading my inlet plenum on my rb26/30, and have noticed that 3 or 4 vendors have popped up on ebay recently selling the same or very similar cast alloy inlet plenums for the rb26.
An example is here:
http://cgi.ebay.com.au/EPR-RB26DETT-Intake-Manifold-Plenum-/290513936378?pt=AU_Car_Parts_Accessories&hash=item43a3fadffa
SOme of the listings state straight out they are copied from the greddy one. In addition to having a larger 95mm inlet, they claim to boltup to the factory throttles and have a much larger internal volume.
THe other advantage is, being a matte alloy finish, they don't have the 'cop bait' look about them that some other polished or chromed ones have.
Just wondering if anyone has purchased one of these yet, and had any comments they'd like to share. I'm particularly interested in:
1) ease of fitment - did things more or less line up and seal at critical points where it is supposed to, including machined surfaces and bolt holes
2) any interference - eg does it foul on the clutch m/c like many other upgrade plenums
3) inlet piping - how much of a hassle is it to source an adapter flange
4) performance - did it make any noticeable change in performance (good or bad)?
5) overall assessment - am I better off paying for a hypertune or similar?
There is no market for something like this...
If you want less than say 500rwkw then a standard one is fine, if your getting serious about big top end power there is no reason why you shouldn't be able to afford a genuine Greddy or Hypertune
As above. Couldn't agree more. I can't see how going bigger is going to offer and performance benefit.
Infact I've never seen results to show the GReddy is any better than factory.
The nismo one makes a minor midrange diff, but for the price its really not justified at all.
So what is the key advantage with the hypertune style plenums? Is it the internal trumpets, better shaped runners/plenum, or something else?
I'm going to be retaining the 6-throttle setup, if that makes a difference.
well the nismo and trust plenum both have basically the same principal. they have better air distribution (factory plenum send too much air to cyl 5+6 which causes them to run a bit lean). and they are larger volume. larger volume is basically a benefit to on/off/on throttle response. having a larger volume of air in the plenum before the throttles mean when you crack them open there is plenty of pressure and volume there to fill the head. the better design does increase midrange and response a bit. the nismo one I think is a little better in midrange and the trust one a little better in top end. the hypertune one also seems to be a good design.
as far as the cheap ones go, personally I'd stay away. they are usually so poorly cast it's a joke. all the copy plenums i've seen were ill-fitting and needed plenty of work to fit nicely. for the effort spent you still have an inferior product and it leeches money off the people who spent the R+D to design the thing. the trust ones are not super expensive. nismo ones are a little more so but not too bad used if you can find one.
as far as performance increase don't expect it to do anything magic. i'm running a trust plenum on my 32 with the 2.7 Jun engine and it seems to work fine (with 6 throttle set-up). the car is quite responsive and has great midrange but how much of that is due to the 2.7 and the combo of the cams and 2530s or the tune in the motec or the plenum is anyones guess as the plenum was on it when I bought it.
Fair enough. The issues with quality/fitment are enough to decide this issue from my perspective. There is very limited space to work with around the plenum of a GTR so any issues with fitment will rule out any knockoffs as an option. Also the amount of screwing around required to remove the plenum with the motor in the car means I will be doing it once and doing it right - having to remove it because of leaks or gaskets not sealing etc is not really an option.
It seems as if the genuine greddy ones routinely come up for sale for $900-1000, whereas the hypertune ones are around $2k, so I'll probably go with a greddy one at this stage (together with an r33 clutch m/c).
I have a RB26/30 and can't help to think the larger capacity will be better. The reduced velocity from the larger intake should also aid better cylinder distribution. The gains due to the butterflies being after the Plenum are not the same as other plenums however. The linkages on the 6 throttle OEM have to be lengthened by 10mm or so. There should be enough adjusment available to do so. Not sure about clearance from the brake lines on the master cylinder. For the money, I will eventually give it a try. The Casting on there is much better than the Rb25 ones.
Matt
lol, do it. fatz is pretty drunk most of the time so there's a 50/50 chance he'll give you the genuine greddy one for $150... :) worth the gamble I say.
ps your engine bay will be tight as all hell now. 6 boost taking up all the real-estage on the ex side and trust plenum is bloody huuuge on the inlet side, plus the fact you've got a 30 in there. you will never get a hand down in there again!!!
my thing is tight enough now with just 2530s with the same HKS piping you have and hks manifolds and a trust plenum and it's a standard block jun 2.7.... I had to move my PS res too but it's actually a good thing as it takes it further away from the turbo heat. mines now up near the passenger headlight and radiator support.
Actually I reckon the rb30 block sitting the head, and therefore the plenum, up slightly higher would improve access to the lower plenum bolts, and give more hand-space in the critical area which is between the transfer case and the underside of the plenum.
Or knowing my luck it makes it worse, more than likely its the latter.
I have to move my PS tank aswell. What did you use for the lines?
Yep ,oil filter is easier to get to aswell.
Matt
as best I can remember it's still using the stock ones. just moved. it;s still about the same distance from the PS pump just different place (now near headlight). I'll have a look. there's only low pres line anyway from res to pump so it's quite easy to change.
hmmm.... dosn't look all that much different to my genuine greddy unit.
bugger!
It'll be interesting to see if there are any gains/losses.
I'm so happy your doing all the testing on alot of parts I'm planning to use shortly. I just won't be going 3lt... stroker for meee :thumbsup: and a little (mm maybe alot) of giggle gas.
Cheers
Justin
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
