  • Replies 89
O/k guys, you want to increase boost with your external gate.
If you want to fit a helper spring, and you want 3 more psi, just go through all the same calculations as before, but for 3psi.
For the "mythical" gate, that would be 3psi times 10 square inches is 30 pounds extra force, with the same mythical spring height of 1.5 inches.
Just add an extra smaller spring inside the existing stock spring with that rated load and height.
But there is another and better way to do it. You still need more spring force, but you can do it with AIR PRESSURE on the spring side of the diaphragm.
So what you have is a stock original wastegate spring rated for maybe 10psi design boost in your external wastegate. To increase it to 15psi, just feed in a constant 5psi of air pressure on top of the diaphragm on the same side as the spring. The air pressure and spring pressure add together., and the wastegate will not open until 15psi.
All external gates have a pressure fitting on the top cover to do exactly this.
How you do this is you tap off some boost air pressure (15psi) and feed it through an adjustable pressure regulator so a constant 5psi comes out of the regulator. Plumb that into the top of the external wastegate, and it will then work at i5 psi.
If you fit the pressure regulator inside the car, you have adjustable boost. Wind the pressure regulator right down to zero and you get the stock 10psi. Wind it up and boost increases to anything you like. Wind it up to 12 Psi and you get 12 + 10 = 22psi boost for example. Easy.
this is how my EBC is plumbed, with the solenoid to the top of the gate and a direct boost line to the diaphram. It holds shut ok, just when the gate comes open it drops slightly then fluctuates as it tries to control the boost. This is only when I am running higher boost, ie1.5bar plus.
The fluctuation isnt bad, but at lower boost its spot on, and the power curve is nice and even, with no dips.
So I am hoping that a harder spring will give me the same boost control that I have at 1.2bar with the 10psi spring that is in there at the moment.
so - sorry for re-iterating, but im still a turbo noob... :P
If you wished to up the boost on an R33 to 11 or 12psi, this could be acheived by installing an HKS wastegate actuator (rated to the appropriate boost, of course) instead of any bleed valves or EBC's ??
Only drawback (if you call it one) would be that you couldnt run any lower boost settings if you wished...
Is this correct ??
Gizmo - I pretty sure this is right.
If your like me and just have a bleed valve set at 12psi, and that all you want to run (couldn't be bothered with a lower setting) then a HKS actuator might be a good idea.
You might be happy with the just the actuator installed so you may not need a EBC or a bleeder :P
I think someone mentioned that you can get a HKS adjustable one too ! Not sure on price though.
J
Yep...
Going on
http://www.takakaira.co.jp/performance/main.html
regarding the HKS Wastegates (whole unit)
Depending on the strength and psi required, they start at about $700AUS...
Still - it would eliminate boost fluctuations, as long as you are happy with that level of boost (as per Jay)
Maybe a good option to get an 10-11psi HKS wastegate, and a good bleed valve for the other 2-3 variable psi...
Guest INASNT
hmm can u explain more about the helper spring :P I can hold around 12psi, but want to hold 1 bar. Its not that much more ;)
Remember it comes down to the ability of your turbo to hold boost up high alao, not only the spring tentioned. Most stock r33 turbos wont hold 1 bar all the way to redline.
That is correct. The only way to take it apart is to cut it apart. It would be easier to make your own wastegate actuator from scratch, than to try to put a stock one back together again.
Not too hard if you have a lathe, to turn up your own housing. But why bother ?
Just buy a replacement actuator from Garrett or HKS for whatever boost level you want to run.
The last time I bought one it cost $220 about three years ago from AVO in Melbourne.
Hmm well i just checked the prices on Greenline, quite cheap. So ill think ill get one.
Now i want to run 1 bar. So do i ask for a 1bar wastgate actutator? Or do i ask for somethin like 13psi and make up the rest with my boost controller?
Will there be any problems putting such a stonger W. A on the turbo? Like will the turbo be able to make that much boost. Bare in mind, i dont actually use the turbo much, onlyu some nights and stuff. Most day to day driving, i barely use boost.
Thanks
Just for everyones info,
I just rang GCG and had a chat to Brett regarding this.
They can supply a brand new actuator, with upgraded spring AND an adjustable rod, with all the brackets and bolts. They are a direct replacement item that will fit in the factory location.
This means that that it should get rid of some wastegate creep (from the stronger spring) and hold boost better up top. And with it being adjustable you can adjust the boost if you find that you want 14psi instead of 12psi.
Brett also said that all you'll need to do is remove the heat shield to remove the stock one and fit the new one.
The price of the unit is $247.50 plus delivery. This price INCLUDES the 10% discount for SAU members.
Now I'm not sure how this compares to the HKS actuator as I haven't used either of them, but to me it seems pretty good.
Just letting everyone know what is on offer etc... I'm not specifically trying to push the GCG stuff, although Brett seemed happy to explain everything.
If we had enough people maybe we could do a group buy ??
J
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
