Hi Guys Im a Newbie for sure But my skyline is pretty awesome need it gone
Im a workcover injury case can't afford it, can't work on it, can't keep it. Please need it gone Here are the Details
White
1996 series 2
130,000kms approx
Manual- 5 speed
SA - Springton Barossa Area
Many mods
$20k worth of Mods and Labour Extremely fast and powerful to weight ratio. But Mostly Reliable.
Induction
- High flowed Standard T3 Turbo with an Garret GT30 Ballbearing steel wheeled Core 300rwkw max capable performed by Adelaide Turbo Services
- Including Sonic Performance Turbo Blanket Heat shield.
- Garrett Water and Oil Stainless Braided Lines.
Custom Made Intercooler and 3 inch piping
-Thick Aluminium Core Stainless End tank.
-600mm x 400mm x 75mm.
-800hp capable maximum flow, minimal pressure loss.
- 300zx MAF meter including custom mounting
- High flow Drift blue urethane pod filter (in recent road test came up best pod filter)
- Custom induction tube to turbo stainless.
- GFB (go fast bits) Stealth BOV can be changed from Plumb back (legal) to ATMO vent with a simple turn of knob.
Suspension and Handling (Carried out by Adelaide Radial and Tyre the drift specialists)
- Whiteline Front and rear Fully Adjustable racing swaybars.
- Whiteline Urethane bushes.
- DriftShop Front and rear Solid adjustable Camber arms and Trailing arms.
- Front Greddy/TRUST Strut tower bar, Rear Standard Strut tower bar.
- Greddy/TRUST Fully Adjustable Type S Coilovers (Prorate spring, Rubber mount for longevity and comfort) adjustable electrically via in cabin can be made soft or hard awesome for cruising with 5 presets. Very comfortable Considering its got Coilovers!!!!
- Bendix break Pads (Standard 4piston front 2 piston rear brakes awesome from factory.)
Transmission- 5speed manual
- Extreme Cushioned button Heavy Duty Clutch, single plate handle up to 350kw+.
- Machined standard flywheel, extreme replaced thrust bearing
- Solid Short Shifter for solid quick changes
- Redline blue Transmission oil.
- Standard Viscous LSD
Engine
- Splitfire Blue Coil pack ignition (4x ignition power of standard coils) to sustain high boost ignition.
- OEM water pump replaced @ 120,000
- Gates Heavy Duty racing timing belt @ 120,000
- Timing belt tensioner bearings replaced @ 120,000
- OEM thermostat replaced.
- Custom made dual core 52mm Aluminium radiator with SAMCO SPORT Silicone high pressure racing hoses (this keeps engine really cool!!!)
- Greddy 1ltr Oil Catch Can vents to atmosphere
- Nismo 720cc high flowed injectors can handle up to 800hp (only at 58% of capacity at high boost never runs out of fuel)
- Genuine Sard Adjustable fuel regulator
- Genuine Walbro 255lph 500hp intank fuel pump
- NGK copper spark plugs heat range 7 only last 10,000km but great combustion (but doesn't knock or ping like Iridium and platinum).
- All exhaust manifold Studs been replaced.
- Full Custom 3 inch exhaust wrapped dump pipe high flow cat and with a 5inch tip
Wheels
- Koyo Drift-Tek very popular rims staggered sets fronts 8.5 offset rear, 9.5 offset something like that im not good with wheels
- Maxis V1 tyres Awesome Grip and Traction for price Brand new
- 235/45R/18 Front
- 245/45R/18 Rear
- Guards Rolled to meet the huge rims
- All legal 18's wheels as car was complied on 16's
Body
- GST-R badges from the rare special edition r31 skyline
- Transformers Autobot badges on side panels looks cool!!!
- Drift and Gates Stickers, easily removed if needed.
- Headlights professionally cleaned up to clear so no cloudy headlights.
- Aero Mirrors- electrical black abs plastic paintable
- Nismo Clear Side Indicators
Electronics
- Apexi Power FC and Hand Commander EFI computer.
- Greddy Profec B 2 Full electronic Boost controller. Set to Low boost (10psi) – High Boost (16psi)
- Greddy Adjustable suspension electronic unit for Soft to hard coil-over in cabin settings.
- B&M Dark face Boost gauge pillar pod mounted, B&M Dark Face Fuel pressure Gauge.
- Professional Blue LED Dash and Climate control back light conversion
- Interior Momo leather Gearknob and Momo Leather surround.
Entertainment
- Kenwood MP3, Wav, USB single CD deck
- Kenwood 6inch splits front mounted in doors Top of the Range!!!!
- Clarion Kevular Cone 6 inch splits rear (for strength with heavy bass!!!)
- Kenwood mono block amp real power awesome.
- US Audio Wiring
- Pioneer 12" subwoofer (Awesome Bowel Trembling Bass) in a US Audio Sub enclosure.
- Optima Yellow Battery deep cycle battery awesome improved bass and engine power heaps Mega expensive!!!
This is my Pride and Joy, my loss is your gain
My Skyline makes 230rwkw on 10psi LOW boost and a staggering 271rwkw on 16psi on HI boost.
This may not seem like much, but with the highflowed turbo it spools up and makes boost as early as 2200rpm and pulls very hard to 7000rpm redline.
It's on par if not faster than 300kw+ Holdens and Fords. IMO it handles better and faster than a standard All wheel Drive GTR like driving on rails. And is just a dream to drive it can be as quiet as a mild sports car or as angry as a flame throwing race car.
Professionally Dynotuned by Jeff from Speed Labs. Was told could easily make 300rwkw+ with a metal head gasket and after-market diff. I was happy as is enough power for street. All mechanicals better than A1 religiously maintained with top lubricants Castrol Edge 10w60 turbo oil and Ryco oil filter every 5000kms and brand new fuel filter. Redline Blue Transmission Oil in Gearbox. Runs only on BP98 ultimate or Shell V power 98 Octane fuel will knock and cough on anything Lower. Can be Economical if driven tame
The bad point needs Paint and has several small dings and stone chips on front and on body. Basically ran out of money to finish project. Got it quoted at $3000 for full body kit, body imperfection fix and paint. Front driver's seat has small tear in side cushion
I have a Unique JUN full Body Kit Included with the sale and an Interior blue leather trim kit. To sweeten the deal. Plus all standard parts that has been removed.
Basically it just needs the body kit fitted sanded back and painted your favourite colour!
Don't spend Thousands on Engine mods its done for the street just needs a body clean up!!
Too easy the mechanical parts all done never been in a crash and finally Air con is strong and cold
Price Was $16,000 now $13,000ono FINAL PRICE DROP with Full Receipts
Call Michael on 0428848963 during day and evening Email [email protected] we can arrange an inspection and test drive.
No Tyre kickers, Joy riders, Low ballers or Overseas Time wasters.
**Dont listen to people who claim their car has a kagillion, bagillion Killowatts and can't do the conversion calculations properly from kilowatts to horsepower. This Skyline has legitmate Dyno-sheets to prove power and torque output.**
Edited by Turbomoehican
https://www.sau.com.au/forums/topic/358516-fs-r33-s2-gtst-lots-of-mods-271rwkw/
Common Guys I need this gone!!!!
Its Mechanical A1 or better regliously maintained and serviced and has many more years in it. I can't work on it I can't afford it need it gone asap!!
All Safe Bolt on Mods Done Just needs Paint and Bling.
Most Guys do this Anyway with no engine or mods this is done so Paint away.
Free Unique Jun Body Kit, Free leather Trim Kit !!!!!!
Pig Coppers Must have scared away most guys nowadays from even thinking of buying a Skyline Sad really!!!!!. which reminds me of a old saying " whats the colour of a 2c piece Copper Copper!!!"
Either that or its a Buyers Market or maybe just the fact way too many R33's on the road Who Knows I just want my car sold Dammit!!!!!!!!!!!!
Come on guys Don't make me PARTOUT a awesome car.!!!!!! If its not sold by the 8th of April 2011 I will Part out car. Pm or email for prices
I know this is silly selling a Skyline on the Skyline forum
But come on gotta sell this soon!!!! goner be broke or worst bankrupt!!!
Im open to offers
will consider all reasonable offers!!!!
I'll take the powerFC and blitz EBC for $900 if/when you part it out.
If and when I Part out
I would want at least $1400 for the Power FC very rare now
and $180 for the Greddy Profec B EBC Not Blitz!!
Does it come with the original body kit, rims, etc?
car has original S2 bodykit on it now comes with free JUN full bodykit. No it only comes with 18's which are legal on this car including the height 10cm all round not illegally lowered. incase anyones wondering
Still for sale ***However Have had a Offer waiting on confirmation, buyer very interested had a look tonight. Possibly will be gone by Easter.***
Still for sale
    • And one last super random thought, I remember when SAUNSW had a dinner with Alan Heaphy, and another with Fred Gibson there was talk of the R32 GTR cast alloy uprights failing in racing, and one of the things Fred did when they had to add weight to the vehicle was taken the failing alloy uprights, and have them made of steel. Does anyone remember back to 1990/1991/1992 and WHAT was failing in the front hubs/uprights?
    • If you truly want to know how the original failed though, was it a factory defect possibly etc, send it off for investigation. Would probably cost a shit tonne.   The ones that you need to win lotto for, unless you have a good reason for that part to be bolt on, I'd probably roll with getting a few small stitch welds carefully put in place as an extra safety factor once everything is all torqued up tight
    • Are you sure? Because I wouldn't necessarily be. Do we even know the material they've made the new uprights from?   Looking at the fractures in the earlier pics, it does to me look like both a twisting, and levering upward action doing the damage, so you're hoping for both compression, and tension. Depending on the bolts, they can stretch (even high grade bolts will) and now you're hoping for the threads themself not to stretch, as if they do, bye bye mating surfaces holding together, hello bolts now going into shear.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
