Hey there people.
Just wondering if NGK laser platinum premium spark plugs are ok to use on my R34. I have heard a few other people mention different ones but REPCO only had these ones in.
Many thanks
Zeebs
I did, but my tuner changed them to the normal style plugs.... Which is cheaper :thumbsup:
I just had to make sure they were gapped correctly and changed more regularly...
Check with a tuner if you want the best answer to suit your given situation.
NGK laser platinum will be fine, they generally have a longer service life than copper. thats the difference. they have a slower wear rate and are slightly more resistant to fowling i believe.
i always use copper plugs. i dont have to pay for plugs but im still happy with copper ones.
the longer service life of iridiums or platinums etc does not come into the equation for me tho because i do the plugs every 5000 anyway lol
i use bcpr7es from memory.
You may as well stick with bcpr6es/bkr6es or bosch fr7dp/fr7dpx which are platinums for pretty much the same price, and change with oil every 5-10k km. Some people have success with long lasting platinums and iridiums, but most don't.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
