  • Replies 46
MMmmmmmm......... and risk getting smacked around... maybe not. If your definately going, let me know. Maybe we can go together.
Geez thanks guys!! ;) As if I would do that!
On that topic, Dean where are my rims??!!!!!! You said you'd bring them back 2 months ago!! :D Might as well use them at the street meet, you've probably already fried my brand new tyres anyway!! hehe :)
Might come out for a look if everyone is going to compete.
hope to have my car out when got exhaust and cooler fitted
**Thats ST Patricks day**
It's also the day before the Clipsal starts!
Will your gear be on by then Matt?
If you're racing, then I'm going to spectate, and I'm sure we could get Andrew to come out (to watch, not break things), shit I'll basically be living at his place while the Clipsal is on.
will you now Will??? :devil: cool ... will have to get out the ps1 and boxload of games then too :starwars: .... yep if you're running Matt then I'll come out to watch. I'm not running until my Z32 afm, S14 throttle body and Hybrid EBC are fitted and tuned. Then I hope to do a low 12 run and retire from drag racing. I am very afraid my gearbox is going to die - I don't think it has long left :stupid:
yep having Thurs and Friday off - told work to go shove it! Anyone else coming along and wanna hook up to say hi .... Pawley and I caught up last year on one of the ovals and were treated to many photos with lovely ladies walking past ... check out Clipsal 500 2003 pics :)
and this fella ... what can I say :D
dude the more I think about it, the more I think your figure of 200rwkw is good. You still have oem injectors and fuel pump, so the 201rwkw is a reasonable figure I think.
But as you said, since the apprentice tuned our cars, a retune by a more qualified tuner would most likely result in better figures at a safer level.
Fyi, when I spoke with John last week, he said that once I got the Z32 afm in, a retune/remap would cost me about $150.
well the car just feels like shit, everywhere in the rpm range, so im worried somethin is wrong. Plus i will get the ecu retuned by John, its just that i am also gettin a new wastegate actuator, and also a new dump pipe, then i will get it retuned.
Basically ive waited ages to take my car to the drags, so i can wait a bit longer if i have to.
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
