44 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 68
Terry and I met with owner today. He did say that there is a fair bit of Skyline and Evo theft in the area to we need to be extra cautious.
He said he would try to clear space in the yard so we have a limited number of spaces we can lock in the yard during the movie.
Please send me a PM if you are interested in reserving a spot. It also does mean that we will have to block cars in so once you are in the yard you may not be able to get your car out until the end of the night. I figure if we end around 10:30 or so we may go to Maccas for hot choc anyways. We'll try to accomodate as many as possible but also means we will have to do our best on the night. If you have a daily driver, you might just want to drive that to be on the safe side in case you can't get into the lot. At this point, I'm not sure how many people will show up.
Keep the votes coming in folks.
god is the crime that bad in the area? spose if u have a shiny GTR you would have to be pretty careful, used to slummin it in my 33.
half ten is good, means i can get there with half an hour left and def up for the hot choco's after. Should i bring a bunch of auto dvds to add to the club house collection?
Will try and make it out to this - should be good! Haven't seen the clubhouse yet either. :)
Mate don't forget you get an extra hour's sleep on Sat night too! Clocks go back one hour on Sunday at 3am.
Hey folks don't forget to bring a chair to the event. Otherwise you'll have to sit on the floor because our club house is empty right now.
Looks like a two horse race - I'll bring both movies and we can do a final vote at the event.
But I have to say that "I live my life a quarter mile at a time" is the corn-eee-est quote evar!
Hey Aggro, if you do bring it let us know so we can bring along some popper corn. I've got an air popper but just not the same, you know.
Can you also bring along that vacuum? I was at the club house and could use a little vac before. I plan to get there a bit early.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
