44 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 68
Terry and I met with owner today. He did say that there is a fair bit of Skyline and Evo theft in the area to we need to be extra cautious.
He said he would try to clear space in the yard so we have a limited number of spaces we can lock in the yard during the movie.
Please send me a PM if you are interested in reserving a spot. It also does mean that we will have to block cars in so once you are in the yard you may not be able to get your car out until the end of the night. I figure if we end around 10:30 or so we may go to Maccas for hot choc anyways. We'll try to accomodate as many as possible but also means we will have to do our best on the night. If you have a daily driver, you might just want to drive that to be on the safe side in case you can't get into the lot. At this point, I'm not sure how many people will show up.
Keep the votes coming in folks.
god is the crime that bad in the area? spose if u have a shiny GTR you would have to be pretty careful, used to slummin it in my 33.
half ten is good, means i can get there with half an hour left and def up for the hot choco's after. Should i bring a bunch of auto dvds to add to the club house collection?
Will try and make it out to this - should be good! Haven't seen the clubhouse yet either. :)
Mate don't forget you get an extra hour's sleep on Sat night too! Clocks go back one hour on Sunday at 3am.
Hey folks don't forget to bring a chair to the event. Otherwise you'll have to sit on the floor because our club house is empty right now.
Looks like a two horse race - I'll bring both movies and we can do a final vote at the event.
But I have to say that "I live my life a quarter mile at a time" is the corn-eee-est quote evar!
Hey Aggro, if you do bring it let us know so we can bring along some popper corn. I've got an air popper but just not the same, you know.
Can you also bring along that vacuum? I was at the club house and could use a little vac before. I plan to get there a bit early.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
