To the men of fire and steel of SAU.
The picture above shows my HKS front pipe for my R32 GTR
The two turbo pipes measure in at ~ 70+ MM each whilst the merged part measures in at ~80+ MM.
Now here is my problem.
I will have a set of HKS split dumps to go off the back of my 2860-5's to dump into this pipe, after this however I plan on running a "venom" 500 series cat (3" inlet and outlet and 5" body")
Link here: http://www.venomexhaustworks.com.au/products.html
This will meet up with my HKS exhaust which is roughly the same size upto a medium sized muffler which then goes to a 4" pipe, terminating at a HKS cannon.
Now my goal is to hit 400AWKW and anything over being a bonus, will this system give me what I want in terms of making the most of the turbos (as I will need to for this sort of power)
I have my concerns obviously, hence I"m putting the question out there.
Yes I know the general rule of around 1" for every 100KW after say 2.5"
I'm looking for literature, peoples experiences first hand etc.
Cheers,
Mitch.
Edited by Nee-san
https://www.sau.com.au/forums/topic/358991-full-exhaust-overhall/
The short 80mm pipe after the twin 70mm front pipes is a bit of a problem, but not too bad as by that point gas has already expanded a lot and velocity is lower anyway, still if you really want every bit then cut off the 80mm pipe, replace it with a 90mm+ pipe ending with a 4inch Vband flange. get a BIG cat with 4inch in/out and put Vband flanges at each end, then run 4 inch cat back exhaust (3.5inch will be ok too in a pinch).
other option, is cut off the 80mm bit and run twin 70mm system the whole way.
personally I'd replace the HKS dumps too. they are pretty small. a set of tomeis are much bigger and allowing the gas to expand as quickly as possible is the aim of the game. you are asking for 400kw from what is on average a 350kw set-up. you really need a decent exhaust to make that happen.
This is cementing pretty much what I had thought myself, thanks guys :)
Is there anywhere I can buy an off the shelf front pipe of the required size, say 3" merged into 4" then 4" the rest of the way back ?
Failing that I will get my workshop to make me up an exhaust and sell the one I have, it's sad because this is a pretty nice sounding setup I have and already makes 330kw :(
PS
Beer Baron,
I have been eyeing off the Midori dumps for ages :D so I guess this is an excuse right :P ?
I made 400rwkw with trust dumps and down pipe, 3.5" exhaust and a (now found out) restrictive 3.5" rear muffler.
If I stay with low mounts, my next exhaust will be, trust dumps- custom 3.5" down pipes- twin 4" cats (on v bands)- custom burns stainless 2x 3.5" inlet, 4" outlet center muffler- burns stainless 4" inlet custom rear cannon.
X2 HKS dumps probably should go.
Good luck.
J.
I currently have 2x3" into 3.5" Makes 455awkw. I put twin 3" side pipes on and it makes another 80kw
If you can pick up a Apexi N1 dual, it would be a simple mod to run twin 70mm.
having sais that a single 4" has about 10% more flow over twin 70mm
pie x Radius , squared = area of a circle(pipe)
yep, just goes to show how much power there can be if the exhaust is a restriction.
I don't know of any off the shelf front pipes bigger than the current model HKS drag front pipes. they are twin 70mm (or 75mm i forget) into single which is at least 80mm (could be bigger). it's the biggest I've found. most are twin 60mm or sometimes they quote 70 but when you measure them that's 70 OD not ID.
the best off the shelf cat back exhaust on the planet for a GTR is the trust power evolution which is 94mm and comes will all V-band flanges (except to connect to the front pipe which is normal 2 bolt flange), comes with a 'fake cat' which is actually a big resonator, with the 2 bolt flange on one side (to meet normal front pipes) and a v-band on the other (to meet the cat-back). it's all straight pipe and just has one rear cannon which is HUGE and is 4 inch (well 3.75 really) all the way through it. no restriction at all in that set-up and perfect for big power.
sadly trust will only make them in batches so need to order 10 or 20 units or some such. and are special order. I don't think they've made any for about 5 years or so. I still have one brand new in it's box, but i'm saving it for a rainy day. it's a nice piece of gear.
I have grabbed some Midori 76mm dumps + 90mm Midori front pipes being the biggest I could find.
Dumps are really nice, much like the older Tomei ones but a bit bigger I think, designed to mate up with the front pipes without any reduction.
Only thing that surprised me is the front pipe for the rear turbo tapers down slightly after the join with the dump - see pics. Not sure if this is by design due to them actually analysing the gas flow, or to make it easier for them to merge at the collector.
post-12551-0-15577600-1301366813_thumb.jpg post-12551-0-47228900-1301366818_thumb.jpg post-12551-0-45366100-1301366823_thumb.jpg
Ok at this point my system is going to look like this:
Midori 3" dumps
Midori Front Pipes OR Custom front pipes, can they be made any bigger then 3" ? if so 3.5" to a 4" merge
Following this, into a 4" inlet 5" body cat.
then straight pipe to a rear 4" muffler at the end ?
peoples thoughts ?
Is getting twin 3 inch system all the way to the back worthwhile ?
It seems it could be taking BOOSTDR's experiences into consideration.
the Full N1 mega twin system is a possibly Hmmm, hard choices.
You dont need bigger than 3" (76mm) front pipes dude. Even 2.75" (70mm) is ok if it's going into 4".
The bigger you go the more drone/noise you have to counter muffler wise. Not a problem if you don't care but 3" front pipes is more than enough. 3.5" is going too far i reckon for front pipe size.
The trust/greddy was not 3" into 4"
I had them myself, its 3-3.25" with 70mm front. I had my trust ones modified to be a full 3.5" merge back in the day.
I'd be asking to see measurements mate to back up sellers claims as they aint like that factory
yeah of all the main off the shelf front pipes the 'new' HKS ones (easily picked as flanges are welded to the pipes on the inside of the flange, not around the outside like normal) are the biggest. most others (trust included) are between 60 and 70mm twin pipe into 70 or 80mm single.
twin 3 inch system is a good idea. it flows about the same as a single 4 inch, but does't hang as low to the ground as single 4 inch. it is also possible to make it a bit quieter than a single 4, though both can be quiet with the right mufflers. the downside is it'll be heavier.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
