Ph# 97902984.
80 rosedale Ave greenacre 2190
How about that, i had a gearbox factory fridge magent laying around from when i got some gear box parts about 3 years ago.
thanks mate!
looked around on whitepages and on the web. couldn't find it anywhere!
cheers, MARK
how much is it costing?
I believe my synchros are on the way out
enough hehe
$751 for reco (inclusive of gst)
$220 + GST to take out box and put it back in
so $970 all up
my synchro's are fine, but no where that I spoke will just fix my bearing. they wanna do the full thing. anyway price is not bad compared to some other places that I got quotes from.
cheers, MARK
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
