Serious Guard Lipping / Making Flutes In Std Guards
Hey guys i hsould i would give you a quick look to what i was up to on the weekend
so i cut some flutes in my fender and this is how i did it
First i cut me flutes in the metal and bended them back untill i liked the shape
i also fiberglassed the other side just 2 layers think basic stuff
i used a flap disk on my angle grinder to quickly sand back the bog
then a light sand and primer coat
then paint and wait to dry :)
now this is the fun bit
I had problems getting the lock and the wheels under my car because the guards were SO CLOSE TO RUBBING so I came up with this
Firstly grab a guard roller or a hammer I rolled them to a STUPID AMOUNT pushed them our REALLY quite far
Then i did my measuring and masking to make sure it was going to look and do what I wanted it to
then here comes the scary part CUTTING
cut a fair amount of slits in the metal and bend them all up evenly with a large set of vice grips/ pliers until you get your desired look
now we go fibergassing I made mine about 3 sheets think if it to thick we can just sand it down
now for bog i put heaps on because once again if you have to much you can just sand it back
(:note: i got my girlfriend to do the sanding work it saves alot of time and hard work ;) )
now here is when it starts to take shape i have now primed and sanded it all back ( i had some small pin holes i used pin hole putty to gill them in re sanded and reprimed i dont have a photo for this step )
but look its starting to take shape now we just paint and clear coat
wait to dry put your wheel back on and take your masking off what you think????
big thanks to my beautiful girl friend as she did most of the sanding work on this job
comments questions??
Edited by Abe2
Hey man when I first started reading this thread I was horrified at what you were doing! I'm a spraypainter by trade and the thought of doing this to a customers car nearly did my head in. Having said that I understand this is a drift car and 11/10 to you for the effort most people wouldn't even dream of repairing a dent in their own car and you've actually gone out and done some fairly involved customizations that have come up looking really good. Keep up the good work.
  • 1 month later...
i had a go at my rears on my gtr using this method(flaring only) couldnt beleive how easy it was i think the bog was the hardest for me. trust im no panel beater. dont be afraid to give it a shot you will be surprised at how easy it is top job abe2
  • 1 month later...
  • 10 months later...
  • 2 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
