  • Replies 96
damn nice shot zennon! i prefer digital myself, im too lazy for analogue :P
my new ride.
background was a bit meh and i got a pinch flat on the way to taking this. jumping gutters on a fixie is something ive got to learn, lol. heaps fun bike to ride tho once you get used to a new riding technique.
sorry for double post, cant edit after a certain time it seems, lol.
couple more shots of the bike.
framing was good, positioning of the bike not so good, lol. was in a rush and didnt take notice of the damn drains behind the bars/front wheel
do want!
I've heard all the cool kids are using 1920x1200 :P
Exif? (esp camera & lens)
Stitched Panorama, apparently exif didn't make the transfer :P
Camera: Canon EOS 500D
Lens: Canon 10-22 Wide Angle (love that lens!)
F-stop: F/10
Exposure: 1/250
Iso: ISO-100
Focal: 10mm
No flash
Just got back from visitting my parents down south over the long weekend.
Grabbed these from Gracetown:
My dog is a mountain goat! She sleft for hours after this :P
And this is my parents backyard:
Cant wait to finish my apprenticeship so I can move down there! So over the city.
Jay, how do you stop?! :P
cant stop, wont stop! wooo :P
nah you kind press back on the pedals. helps when the pedals have toe straps on them, and a front brake helps even more. for now i just ride it slowly so i have plenty of space to slow down in, lol
Edited by Jay019
Thanks - was a bit of work.
Here is one from the weekend. Car belongs to Steve - the new owner of City View 4WD park outside Beaudesert.
Winch Truck by ZENN0N, on Flickr
Edited by ZENNON
