G'Day,
Could anyone tell me what I need to do to solve the running lean problem I currently found out I have. I took my r34 (full 3" exhaust, FMIC, 12psi boost, pod in cold air box, and just got Nistune installed) to get a road tune with NIstune installed (onto my stagea DET ECU) and my tuner told me I am getting a dangerous air / fuel ratio of around 13 to 14 which I saw on his laptop, idle is around 15, so I couldnt get it tuned and was told not to rev above 2500-3000 as my engine could blow.
I have been driving like this (running lean) for 10months and was told I'm lucky that my engine hasnt blown so far lol..
Please dont ask why I have a stagea ecu in my skyline, it was there..!! But the Nistune daughterboard has the R34 maps on it.
I was told to get a Bosch 044 fuel pump as my fuel pump could be gone. But he took the time to explain to check the voltage between the modulator and pump - if its above 13V, then I need to cut the ground wire to the modulator and ground it to the chassis. If it is less than 12v, then my pump is screwed. What is this modulator, any pics of it on a R34?
I think I might as well get the fuel pump done, but R34s are still kinda 'new' how can my pump be farked?
Not only that, he adjusted my timing (tapping on the cylindrical grey metal cup object (held by 3screws) on the front of the engine timing cover) to the factory 15 degrees as it was set at 10 degrees before? Is this the way to go?
Any suggestions anyone? (My tuner is excellent, a great bloke, and takes the time to explain things, I will not name him in case some of you don't agree to his advice).
cheers
https://www.sau.com.au/forums/topic/359626-running-lean/
  • Replies 77
Posted Images
R34's are not kinda new. They are over 10yrs old.
So of course the pump is struggling, you are asking more fuel of it given you've wound the boost up.
GT-t/GTS-t pumps are not well renowned for being decent when you ask anything more than stock, after 10 years.
Either way, read the FI Guide:
http://www.skylinesaustralia.com/forums/topic/66556-forced-induction-quick-ref-guide/
It has a link to wiring in pumps. Or simply look in the DIY section. There are some in there too.
https://www.sau.com.au/forums/topic/359626-running-lean/#findComment-5743291
Thanks dude, looks like the fuel pump will need to go, and the 'thing' that he tapped to adjust was the crank angle sensor I think.
Before I end, I would like to add that my fuel sender unit is farked already a few months back (fuel gauge goin up and down), is this a good indication of the likelihood of my pump bein rooted as well?
cheers
https://www.sau.com.au/forums/topic/359626-running-lean/#findComment-5743305
044 is huge. Dont think u will need that big.
Its either the fuel pump or the tune. As long as ur tuner knows how to tune nistune.
13afr under boost is quite dangerous. Would be getting pretty hot in the combustion chambers.
If u go to q workshop they should be able to fit a fuel pressure and flow gauge. This will tell u if ur fuel pump is running out of flow.
https://www.sau.com.au/forums/topic/359626-running-lean/#findComment-5743471
Tomei which model no.? Will have a look on ebay. Tuner definitely knows his stuff, thats why he didnt tune it, said its too dangerous when he found out that its currently running 13+ A/F ratios. He suggested as I said above, to check the fuel modulator whatever that is and moreso the fuel pump.
https://www.sau.com.au/forums/topic/359626-running-lean/#findComment-5743489
So he didn't try tuning it because it was lean? Am I right in saying that a tune could stop it running lean? A stagea ecu in an r34, the injector multiplier is probably out causing it to not get enough fuel. And on idle it would be running on closed loop so it would stil idle on 14.7...
But either way I'd get a new fuel pump, as maintenance if nothing else...
https://www.sau.com.au/forums/topic/359626-running-lean/#findComment-5743512
Nice point Pat, thats what I thought, why couldnt he stop the lean-out with a tune, but then he did, he brought the a/f ratios down slightly by using the stock maps or so he said, and retarded the timing for safety.
And excellent point about the stagea ecu multiplier, maybe thats the reason?? But yes I guess a new pump wouldn't hurt. Still dont know WHY anyone would put a goddamn stagea ecu in a 34.. :(
https://www.sau.com.au/forums/topic/359626-running-lean/#findComment-5743521
stagea and R34 injection multipliers (K-CONST) are the same. they both run the same injectors and AFM. besides, i remember in your other thread you were getting matt to load R34 maps on when you got nistune, so that should clear any doubt over incorrect values. as for the reason someone put it in there, maybe they really needed a new ecu and a R34 one was proving hard to find.
definitely look at the fuel pump, try bypassing the dual voltage modulator. even the fuel filter my be all blocked up, when was the last time you changed it? walbro's are ok cheap and easy to fit, i'm running one in my stagea and have been for a year or two now without any issues.
Edited by QWK32
https://www.sau.com.au/forums/topic/359626-running-lean/#findComment-5743561
I will give a crack at installing - just reading the Nissan Silvia forums, everyones recommending the walbro over the bosch for easy install, plus u get the parts like sock, plug, wires..
Nismo/Tomei are top shelf stuff not worth spending the extra quid on unless u building a dedicated dragster / time attack car etc..
https://www.sau.com.au/forums/topic/359626-running-lean/#findComment-5743566
Hey thanks Josh, I changed the fuel filter almost a month ago and noticed a sharper and crisper response afterwards so thats cleared. Here comes the pump now. So which Walbro model?? I heard there has been a lot of fake Walbros floating around esp in ebay, hence giving the brand a bad name.
Who sells cheap genuine Walbros in Syd, I wanna know you..
https://www.sau.com.au/forums/topic/359626-running-lean/#findComment-5743573
Completely wrong.
They are "top shelf" because they directly replace the factory fuel pump in the exact location and are a direct plug and play.
Walbro and Bosch are not and require a lot of dicking around to get right. Especially for some one that has never done one. You will most likely install it to high and get fuel surge every time you turn a corner with less than a 1/4 of a tank as so many people on the forums do.
If you know how to install one perfectly, then fine go for it.
I have installed all three. In Skylines and in Silvias. The Tomei/Nismo is well worth the money.
https://www.sau.com.au/forums/topic/359626-running-lean/#findComment-5743583
i'd start by looking at what deals the site sponsors (e.g justjap, kudosmotorsport, etc) have going. they may be $10-$20 more expensive than the cheapest ebay deal but at least you know your getting the real deal. a friend got one from autobarn about a month ago for around $170, might be worth seeing what they have.
if you want a walbro you will want to get a GSS-342 or GSS-341, the only difference between the two is the fuel outlet it to side on the 341 instead of in the center like the 342. the 342 is the more popular one.
edit: Phil, the walbro was a direct fit for me, electrical plug was the same and it was a perfect fit for the stock location. though a stagea has a different fuel pump mount than a 34 i think, its in a cradle/box on the bottom of the fuel tank.
Edited by QWK32
https://www.sau.com.au/forums/topic/359626-running-lean/#findComment-5743591
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
