Hey guys I own a s13 silvia, which is fairly modded in terms of suspension, brakes and all the rest, and I have put a rb20 in it which has a high flowed turbo, front mount and a few other things like after market bov and is running 18pound. I'm at the point where i need to buy a aftermarket comp and im wondering whether i should bother, or build up a decent motor.
THese are my options; I own another rb20 block, 26 crank, rods and would buy a 26 head. I believe that because the bore is the same across the rb range, and only the stroke is different (apart from block differences,more modern as they progress) that I could buy forged rods (decrease the stroke) and dome top pistons (increase the subsequently lowered comp ratio) and get closer to a 2.5/2.6 litre that revs harder than a 26 and of course a 30 (as the 30 is limited by its stroke) and avoid the older tech of the 30 block, and get away from the oiling problems of the early 26's. By going to a twin high mount turbo set up (splitting the exhaust with firing order in mind, same as the 26). By changing the head studs to something stronger, and running a thicker metal gasket, the volume increase, and a subsequent compression loss occurs, allowing ultimately for more boost (due to the lower compression) and the twin turbo's will lend themselves to the lower comp, given that they will kick in earlier (than a large single) and make up for the lower na power prior to boost.
Essentially This first option would be a hybrid 26ish, except substituting the block for a rb20 and making up the for the volume difference in bore, stroke, and piston caps, all things that would be changed in a serious 26 or 30 build.
The second option would be to opt for a tradition 26 head and 30 block (there is something to be said for following a trend, look at the vl turbo's quarter times)
and maybe a third option would be building up a late model 26.
P.s guys i apologize for the dodgy shit, that's been going up the last few days, a mate hacked me and put up all the crap.
Your american arn't you...
better do a little more research mate.
Justin
Na dude, I'm australian, research with regards to what?
Edited by Overnight Parts From Japan
Rb bore sizes are the same for rb25/26/30
rb20's have a smaller bore champ.
Sorry my bad, just checked and your right, do you know if they are able to be bored out to 86?
you might be able to get it out to 82, but to make the 26 head fit (if it is indeed possibl) you would have to use bore sleeves.
I like the idea mate, but being limited to the RB20 head is probably your greatest downside in this project: read: there would be expensive headwork involved in properly taking advantage of the increased output ?
what does everyone else think ?
Dude - search function.
Put "RB24" into it. Watch the joyus results roll in.
There are entire threads listing in detail exactly what parts you need, what needs to be done and so on.
For the price, RB25. RB24 is simply not worth the money as you'll soon see by searching and reading past threads about it. Hence there are very little.
Thanks.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
