Got something pretty cool here - thought you guys would appreciate this more than many. We've made a new connection with the guys from D's Club, the US subsidiary of Option Japan and these guys have just released a very cool E-Mag of the R35 GT-R.
It's 160 pages deep, all in English and also covers the newest 2011/2012 model R35. There's tons of other stuff in there and I reckon it's a proper bargain at $8.90. We're not getting anything from each sale, just advertising fees on the site each month so DL it or not - your choice but we reckon it's worth a look, especially if you own an R35. :yes:
Check it out our review on 7TUNE HERE
You can download it through the links we've set up between D's and 7tune.com :thumbsup:
Here's a few shots...
https://www.sau.com.au/forums/topic/359914-r35-gt-r-complete-file/
Nice!
That is awesome.
I love the Mine's page spread.
I saw this on 7-Tune too.
Are you Adam Zillin?
Yep, that's me mate. Actually debating whether or not to take on ownership of a GT-R myself... driven so many of them over the past few years - most memorable being this bad boy up in Hakone...
Clicketty Clicks
If you own a GT-R, you owe it to yourself to see just how good the AP Racing monoblock upgrade is over the standard setup. No comparison.
Awesome!
I guess if you can afford one then go for it :D
Clicketty Clicks
Link no work...
1 day when I get a R35 GTR, I might find out :thumbsup:
Nice subtle changes, so how does the factory Brembos match up to the AP Racing calipers?
Only problem I have with the R35 is that Nissan charge top shelf Euro prices for a Japanese product.
I know they are trying to step up to that level but still...
True, I guess at the end of the day, it is just seen as a 'Nissan'...
They don't! The standard brakes are good but 400mm of CC material and a mono-block floating caliper make a ton of difference. They're the same brakes they use on the Super GT cars. :thumbsup:
ugh...we just got hit by another 7.1 quake
Fuck!
Hope you and everyone else is ok...
Awesome!
Never enough stopping power, I say.
Fuck!
Awesome!
Yeah, nothing damaged but we've had almost 1000 of these bloody aftershocks for the last month now. Slightly unnerving.
Check this link out - it's like earthquake popcorn... http://www.japanquakemap.com/
And I couldn't agree with you more - I used to think that power was everything but now realize its worthless if you can't stop...:laugh:
Great to hear!
Hah! Same here :D
Overall balance is the key, I say.
You will need stopping power to match the horse power.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
