The way you put it i thought there was oil coming out...... I've never done it so not sure, but i dont see any pressure register on my mech oil pressure gauge when cranking for a while, but i do see the oil light come off on the dash and those two are side by side
Edited by Don Dada
https://www.sau.com.au/forums/topic/359966-wierd-problem/#findComment-5747551
how long do i have to crank it before i see oil coming out of the turbo feed line?
sometimes it can take a few minutes of cranking with no spark plugs in before oil will come out.
We used to prime new engines like this before I built the super dooper prime canister thingamy
https://www.sau.com.au/forums/topic/359966-wierd-problem/#findComment-5747980
right so I cranked it for a min and nothing came out so you suggest cranking a few more times? if still there is no oil what could be the problem? i mean if the oil pumps shat itself my engine would be dead right? e.g bearings gone etc
https://www.sau.com.au/forums/topic/359966-wierd-problem/#findComment-5748596
I blew a turbo so I have a new one sitting here I wanna make sure I have oil going through the feed before I put it on.... So I guess I'll keep trying to crank it ey but normally does it take more then 1 min of cranking to get oil Cming out? I have a greddy oil filter relo kit
https://www.sau.com.au/forums/topic/359966-wierd-problem/#findComment-5748974
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
